Joshua Tree 3/17-3/19
What?!! It was sounding so good after the new part? But not totally surprised after seeing your strainer and fuel pump ..I would figure your injectors have suffered as well there's no way they wouldn't all the crap the strainer couldn't catch anymore the injectors have. When you go WOT and under load ...dribble dribble and still need to advance that timing properly ...all this I know you know I'm just affirming what we talked about since it happened on your way home...you know I will come help no problem brotha.
The main culprit is the tps(throttle position sensor). It aids in telling the CPU how much fuel to deliver in correlation to the butterfly valve. It's a easy adjustment with the proper knowledge and multimeter. It started the second I turned out of your neighborhood then I know it was the tps and/or the injectors.
And to add the bubble on the rr tire didn't get any smaller by the time I got home...some new tires are coming soon
No butcher you were correct. My pleasure as always, glad to have you and [MENTION=60694]TheSentinel[/MENTION] along, even after that dirty lil detour from our planned route. "Honestly I was lost" but just so happened to be directly to your camp...a/c, tv, and h****** & b*** ...I don't blame you that was a smooth dirty move, which I can appreciate.
After I plugged in my Garmin GPS in, I saw my grave error in BaseCamp. I apologise. Next time I'm out, if I'm tagged to lead, I will have the exact route designated. But yes, the placement of that wrong turn was rather convenient...
Sent from my SM-G900P using Tapatalk
Hahaha luv ya brotha.
Awesome TWxT4R meet, thanks Danny for organizing it. Here's some of the pictures I have of the trip, a couple pictures are from other members that I stole off IG lol :reddance:.
Watch it guys the 2nd Annual Chili Cookoff Winner is lurking...
Congratulations again brotha, job well done. Hopefully we can wheel soon together.
For sure brotha!
Second that.
Glad you guys had a great time.
Looks like the trail is not technical. Exactly what I like.
Depends on where you go. We found a slightly more technical spot right around the corner from camp, but most of the roads were very 2wd friendly. I still have a LOT of exploring to do out in that area.
If you're going to do a day trip LMK, I'd like to go.
AlaskaRuss
