Jross's Shock List
jross20
Alright, this is the first time I've tried an embedded excel thing, we will see how well it works.
<iframe width="700" height="300" frameborder="0" scrolling="no" src="https://onedrive.live.com/embed?resid=AABA2A188A99A0C5%212819&authkey=%21AAXlCne3QxkkBwo&em=2&ActiveCell='FRONT'!B2&wdHideGridlines=True&wdHideHeaders=True&wdDownloadButton=True&wdInConfigurator=True"></iframe>
Hey it works! Alright, so hopefully this helps folks out when they are trying to figure out which shocks they may want. Lastly, if anyone has any data to add please let me know so I can update my sheet.
Tokico Blacks should be on the rear list for sure, though I don't have any information for the table other than they're $45
In fact, that's why i'm recommending it :bump2:
King's are progressive valving. All bilstein options (4600,5100, 5160, and 6112) are digressive. Icon's are digressive.
Measured Tundra 6112:
-Collapsed - 13.23"
-Extended - 18.35"
-Travel - 5.12"
4Runner 6112's are the same measurements as 4Runner 5100's
Tundra 5160's are an option for the rear if you swap the bottom bushing out. Part #25-261332 (not side specific)
-Collapsed - 13.84"
-Extended - 23.23"
-Travel - 9.39"
Sonoran Steel sells their Classic 1.2 Lift with either FJ80 rear shocks or Bilstein extended travel shocks for an FJ Cruiser. Bilstein shocks for an FJ cruiser are part number 33-187174.
-Collapsed - 14.91"
-Extended - 23.5"
-Travel - 8.59"
Source:1996-2002 - Classic System 1.2 [96-02_complete] - $1,575.15 : Sonoran Steel Fabrication LLC, Toyota Truck Parts
https://wheelersoffroad.com/shop-by...003-4runner-2007-fj-cruiser-33-187174-x2.html
Are you sure front icon's are twin tube and front dobinson's are mono tube? I thought it was the other way around.
Edit: To be accurate I believe you only have the standard king's listed for the front suspension. There is an extended travel version, but I am unfamiliar with the extended and collapsed lengths for them.
Edit 2: FJ80 Rear Tokico Shock
-Collapsed - 14.5"
-Extended - 23.5"
-Travel - 9.0"
Source:Wayback Machine
-Collapsed - 13.23"
-Extended - 18.35"
-Travel - 5.12"
-Collapsed - 13.84"
-Extended - 23.23"
-Travel - 9.39"
-Collapsed - 14.91"
-Extended - 23.5"
-Travel - 8.59"
Bilstein 5100 Rear Shock Set for 2003+ 4Runner, 2007+ FJ Cruiser (33-187174 x2)
-Collapsed - 14.5"
-Extended - 23.5"
-Travel - 9.0"
Go it, I'll update the report later today
Not sure what happened but the icons should be mono and the dobinson's should be twin.
Okay sure, any idea who may have have more information on them?
I just don't know anything about them, which ones should I add? Model, specs?
Fox 2.5" Factory Series Front Coilovers for 96-02 4Runner
FOX-883-02-023 0-2" lift standard travel
FOX-883-02-024 for 0-3" lift extended travel
Monotube
Everything I am reading says Fox are progressive, but couldn't find anything on their website about it.
$1295 on wheelersoffroad
Do you guys think this is sticky worthy? Or perhaps it could be added to preexisting sticky? I was hoping this could be used to help the community out in the long run
:gossip:
Also, any updates I should add?
The 4th gen 5160's are (basically) the remote reservoir version of the 33-187174 (extended travel 5100's)
PN: 25-227611
2.5"-4" of lift option for 3rd gens
Collapsed Length (IN) 14.83
Extended Length (IN) 23.5
~$380/pair (that's what I paid at Wheelers)
