Just got my vehicle back from the dealership....
714runner
On Wednesday I went to my local dealership to try to get them to replace the front headlight lens that were hazing (I had the TSB I got from t4r.org :thanks:)
The dealership had to get a "goodwill" from their manufacturer to fix the problem because the vehicle was out of warranty at 36020 miles, just barely over. My maintenance light was also on so I thought it would be a good time for an oil change as well, my extended Toyota Care covered that expense so I pretty much didnt have to pay anything, although I had to leave my vehicle there overnight so they could do the headlights.
The next morning I get a call from the dealership trying to up-sale me by saying my throttle body and carburetor had a lot of carbon build-up and they had a coupon to clean it for $180, but I knew what they were doing so I said "maybe next time" plus I'm not experiencing any symptoms of carbon build-up in the throttle body so maybe I could put it off for now.
An hour later when I arrived to pick up my truck, I checked out the headlights and everything seemed great, so on my way I went. It was pretty warm when I picked up my truck around noon (Can't beat that SoCal weather) so I decided to turn on th AC. That's when I heard an unfamiliar noise I'd never heard before when I had the AC on. The noise was coming from inside the glove compartment, and it sounds almost like the noise a laptop/pc fan makes, just barely loud enough to notice it. I was parked in a target parking lot next to a busy street when this happened, so you can get the idea of how loud it was when I noticed it
Am I just paranoid because I just got my truck back and I'm on the lookout for these things or has there always been this noise but I've never heard it before? Can anyone tell me if they can hear anything from their glove compartment besides the sound of air blowing when their AC is on?
I have never heard a noticed being emitted from the glove compartment when the fan was running. I'd pull out the the cabin filter just to see if something (a leaf?) may have gotten sucked into the intake and is fluttering around.
My local dealership stripped one of the screws that holds the lower cover underneath the bumper on when they replaced my headlights. Of course, I didn't find out about that until I changed the oil after the service.
I think I know what you are hearing. This happened in my 4th gen. The service dept pulled my cabin air filter out (to try to sell me a new one) but I did not buy and they forgot to put the old one back in. First time I turned on inside air I could hear the fan was twice as loud. Replace the cabin air filter and problem solved.
What dealer did you go to? I want to make sure I don't go there.
Toyota Place in Garden Grove off 22frwy.
It doesn't really sound like a leaf rattling in the system when I lisyen closely it sounds more like a hissing sound.
I called the dealership and they told me they will check it out, hopefully they won't mess anything else up
I guess they pulled (to check? to clean?) your cabin air filter and put it back. However, there is a chance that debris from your air filter felt down into a blower and are making noise right now.
I had similar situation cleaning filter myslef, so it's real time experience.
Pull out cabin filter on your T4R and carefully inspect blower blades and top of a housing unit with a flash light. It might be hard to pull debris back...I had leaf stem stuck in there so I've used shop vac to get it.
Do me a favor and tell those IDIOTS that vehicles haven't had carburetors since the late '80's will ya?
:dammit:Morons.
if you don't put the cabin filter in there the right way, it will hit the fan blades and make a loud ticking noise(my bad).. happened on my mothers gs350.. they covered it under warranty and replaced the blower and filter (they thought the blower was bad) lol
REE
