Just Installed THESE Performance Parts on my G!
Thai
Elite Member
Just Installed THESE on my G!
Hey all,
After much research (as i always do) into various aftermarket brands, i just installed these babies on my G500...my certified ASE mechanic told me that it would probably increase HP by at least 10-15 hp! :) And it's clean for the environment too! I would highly recommend them for 4runners and other vehicles too.
"You've heard of the Y pipe.. the X pipe.. the H pipe.. nothing can touch the O pipe!!! It provides 100% back pressure feedback on ALL engines!! Torque increase and kuneutson valve float brings in much lower revs so you don't hurt your motor! Not CARB Legal. Please specify standard or polished finish. Product shown is dual input O-Pipe with standard finish."
In addition, i also got some seat covers for my two front seats:
"Sheepskin. Leather. Neoprene. Cloth. A recipe for boring? We thought so. Sure, you could go with the flow, be a regular boring Joe like everyone else. You could don your toupee, gold chains, and slide onto those boring old sheepskin seat covers. But you won't. You're a discerning KaleCoAuto customer. You demand more. Well, put on those Oakley Blade sunglasses and your best pair of parachute pants and jump into your car - because you just bought the coolest seat covers around. Porcupine seat covers. Only for the adventurous, never for the boring. Porcupine seat covers are made with no less than 4 skins per seat! (That's about 120,000 quills, if you are counting.) Each quill is held in with a high quality resin that not only makes the seat stain proof, but also prevents the dropping of quills. Each seat is guaranteed for two full years."
You guys should check out the rest of the stuff on this site: http://kalecoauto.com/index.php?main_page=index
A lot of cool stuff for your car!:)
I am thinking of getting these for my Corolla:
"Want improved braking? Why just cross drill those rotors? Introducing KaleCoAuto cross drilled brake lines! Improved airflow through lines provides superior brake cooling. Brake fluid is exposed to cool moving air, almost instantly reducing heat, and providing shorter stopping distances! All lines are made of quality latex. Brake lines come in: Red and Yellow. Please specify color when ordering!! Warning!! You must replace ALL brake lines at once. You may mix colors."
And this since it's pretty cheap mod for my Corolla:
"Modern synthetic oil is very expensive - so why run the risk of getting it dirty by running it through your motor block? KaleCoAuto bypass kit comes with everything you need to run the oil around your motor block where it will do more good. Oil runs cooler, and as a result, there may be horsepower gains!"
What do you guys think?? I think that it should be at least better than OEM.
What does this have to do with 4Runners? We have to sit you down and explain the rules to you!
Koz
Koz
I will harshly reprimand myself! :D I will move it to Off-Topic.
BillM777
