4the Gen Snorkel Info and my install
What is the toper you have on your snorkel?
It’s a self-ejecting precleaner from Donaldson. But there are other companies the make them like Sy-clone, Engineaire, Turbo Precleaner, etc. Precleaners will minimize entry of dust rain water, bugs, snow, etc into the snorkel instead flipping the head. You have to choose the correct prefilter for the engine CFM range. Typically, the gas engines for 4Runners have a max cfm just under 300. So you’ll want something that does 0-300 CFM so that the paddles inside will spin.
https://youtu.be/_6AxqFVipbA
Rago Fabrication brackets. I had to slide the lights in and it's still close, but they fit.
do you have a close up of the Rago brackets when the hood is closed? wanna see how they look, or maybe a view from driver seat. do you personally feel like they block any of the view? Thank you
They block less than the rearview mirror.
When i installed mine I had to cut apart the fender in order to get the hose to fit. Also it was a pretty tight stretch to get them to attach.
did you remove the stock airbox entirely? Also can you link to the fitting you used to connect the snorkel tube to the car intake
Using Chrome? Try this: Photobucket Hotlink Fix - Chrome Web Store
Pics work fine for me. :biggrin2:
eff pb.
*there are versions for firefox/other browsers out there also.
edit: Glad I could help folks view this content the way it was intended, apologies to [MENTION=165403]afiremensrunner4[/MENTION] for the threadjack. I like your snorkel set up!
It's all good man. This was my first write up so I will try something else next time.
2001ATL
