KidVermicious
I had 8 years of great fun with this little rig! And it is as reliable and easy maintenance as a Toyota. :bravo:
What tires are those you were running? They look like great clay/mud tires.
For now, it is not a builder. Although, I am considering slapping some AT's and a rear locker on it for Moab in April (just in case I can go).
A sammy on 31s is nothing to scoff at though. They don't need much tire to get great clearance.
On the short list of things I like less than 3.0's, that 1.3 makes the grade. Hell, samurai's would be downright quick with a good 3.0
U can swap in the 1.6 16V motor out of a Geo Tracker/Suzuki Sidekick. It's a direct bolt-in and doubles the HP. Checkout SuzukiConversions.com
No they wouldnt. The 3.0 is around 400 LBS & produces about 150 HP.
the Suzuki Sidekick motor weighs about 1/3 of that & prodices 100HP (& yes it weigs less than the 22re)
Harnice..!ound:
your correct. But would you add a 500 horse Volvo/Cummings Semi motor to your 4 runner????? The weight would not be worth the Hp gain.Call me silly, but maths would indicate that adding ~250lbs to the weight of a hairdresser's car in the name of roughly 50hp would improve the power to weight ratio, a lot. And as much as the three-oh isn't a torque monster, 180lb-ft has got to be much much more than the four-pots they throw in those things.
Harnice..!ound:
Dude can't spell OR do maths.
If I had a Samurai, I'd drive the little thing around shirtless, topless, at redline 24/7 through town as fast as possible. I'd basically treat it as disposable.
You have a 8 or 16 valve? (the 8 valve is throttle body injection & the 16 is true fuel injection, better mpg, torque & HP) Exactly why you wouldnt want a heavy 3.0 or similar motor in your samurai. They can & will go anywhere because they are so small & light weight! (same for VW bugs)I have a 1990 samurai I put a 1.6 2 valve FI in it I use it for ice fishing it is amazing what it goes over when other vehicles sink I was going to put track on it but I didn't need to . great little truck I put a hard top and built behind the cab with 1in square and covered it with a alum skin. I am going to put a rear window this summer
4.3 Vortec conversion
