Just when I thought I was done with mods,
zonzin
Member
I just had to do this one. I have plenty of brass, and nickel, so this was easy and cheap. :)
WP_20170215_10_59_01_Pro_LI_zpsbsp5w6fe.jpg~original
WP_20170215_11_00_37_Pro_LI_zpsmhqzzewm.jpg~original
Now I'm done. ;)
Did the cases thread on or did you to use an insert
Sent from my SM-G930U using Tapatalk
Actually the cheap plastic caps are approximately .40 outside dimensions. So add a touch of superglue to the inside of the case and slip in the plastic caps and voila, cool caps.
With my luck i'd be denied access to an airport or refinery for "ammunition"... That being said, anything i can do to keep them from looking inside for lose ammo is worth its weight in gold.
Maybe i should put Hillary stickers on my valve caps?
With my luck i'd be denied access to an airport or refinery for "ammunition"... That being said anything i can do to keep them from looking inside for lose ammo is worth its weight in gold.
YMMV.
Most people who aren't idiots can tell the difference between brass and ammo.
...people who aren't idiots...
And I'm sure that there is a bunch of loose ammo under the seats and rear cargo tray in my truck.
delislerebecca
