Kenwood double din to OEM reverse cam help!!!
808stinkybutt
Hi I was wondering if anyone knew how to hook up the OEM reverse cam to an aftermarket double din. I did search the forum and someone said you could get the wire from the A pillar or something like that but what color is the reverse cam wire? Any and all help is appreciated. Btw I have a stock sr5 non nav head unit on my '11 runner. Thanks!
Do you have a factory navigation screen, or is the reverse cam in the mirror? If you have a factory navigation screen, then the camera wires would be behind the screen. If not, I think they would be up by the mirror, so you would need to tap into it and run it down the pillar to the aftermarket head unit.
As far as the wire colors, the best thing to do is download the electrical wiring diagrams and figure it out that way...you can find the link to the FSM in this below thread
http://www.toyota-4runner.org/5th-gen-t4rs/92594-modifications-write-ups-quick-links-faqs.html
bluelinepilot
