Kicker Subaru Tweeter Upgrade for 4runner?
I was happy to be able to move these from my last Tacoma to the 4runner. Also reused the 6x9 in the front doors. Still need to order a dash kit for the HU.
I used the taco tunes adapters, tiny bit of pipe strap on each side, and 300Hz bass blockers to install Hertz DCX 87.3 3.5” speakers. Also had to trim the underside of the driver side grille to fit with the new speaker. It was a science project compared to the Subie tweeter upgrade but fun to do and the sound is crazy good!
looking into using the Hertz DCX 87.3 speaker as well. Installation tips?
did you need to trim the brackets or were you able to use existing?
are the adapters needed? link?
pipe strap?
bass blockers needed?
Just dropped in a set of Infinity Reference 3032cfx 3.5" speakers and wow what a huge difference! Wish I would have done this sooner, great $50 upgrade. Guess I'll keep the ball rolling and upgrade the rest of the speakers...
What all was needed to swap these in? Im guessing some trimming on the brackets needed to be done?
ordered the kicker subaru tweeter for quick install. Hopefully an improvement of current ones , not looking to go high end or anything. Simple and quick install
I installed mine yesterday. My rig only has ~500 miles on it so not sure if that’s why, but I had a really hard time getting the passenger side hardware off. I had to use an impact to finally remove them.
Once I installed the tweeters the highs were definitely noticeable as an upgrade. Unfortunately to me, it made the rest of the factory speakers sound super muddy, unbalanced and substandard.
I wound up finding a deal on the Focal 6x9 front & 6x5 rear speakers. $300 for all 4 speakers which they normally go for ~300 pair. They are a super easy plug and play affordable option if you don’t install their tweeters. I installed them and a Kicker Key 200.4 amp. I was contemplating a head unit upgrade and adding a sub but for the way it sounds now, which is crisp, clean and loud, those are no longer a priority/necessary.
not bad deal on the focals, kinda wish I upgraded all my speakers. I came across a similar deal for focals but passed on them. The tweeters were a good upgrade but leaves you wanting more. I have a 17 sr5 and would like apple care play but dont want to upgrade stereo yet. May upgrade to a 2022 model 4runner
Subaru Kicker tweeters and OEM Plus Door speakers (6 of them) is what I'm installing to get best combo. Call OEM Plus if you need a deal on speakers without front tweeters.
Toyota 4Runner | Speaker Upgrades - OEM Audio Plus
Subaru tweeters little larger and I like that those are contained which keeps sound from bouncing around behind them inside dash cavity.
Are the kicker tweeters better than the OEM Audio+ ones? Just installed the reference 500 system and swapped out my kickers for the OEM Audio+ ones.
I just installed Focal 6 x 9" 2-Way Coaxial IS 690 TOY kit this evening. I tried the kicker tweeters with focals and the tweeters came alive compared to stock. They sounded great! I'm going to try the focals for awhile to see how I like them. Theyre a tad small compared to the kicker, I may end up going back to the kickers
Did I miss how to upgrade for the JBL system?
My 2016 Limited has the JBL system and my dash speakers are shot. This discussion went all over so I remain confused as to what I need for the JBL.
I do not want to cut wires and since the stock factory dash speakers puked their guts I am not interested in buying the stock factory JBL ones. How did others with the JBL system fix the issue for the dash speakers?
Cut the wires and butt connect the new wires in place. Its been quite a few years, like 2014 i believe, but i took ours out of our 2012 Limited with JBL. If i recall correctly the fronts are a paper cone made to the plastic basket and the plug on the speaker runs the wires down to the voice coil.
I believe once you unplug the OEM speaker you have a flat 2 wire plug, i dont think anybody anywhere is going to make an aftermarket speaker that plugs into the factory toyota harness. If you want aftermarket speakers you are most likely going to end up with cutting the flat 2 wire plug and butt connecting, splicing, soldering, in a new wire and flat blade speaker terminals for aftermarket speakers.
mek
