KN Intake Install (Pics as requested!)
D16RR
As per requested, here's a detailed step by step with pics of the KN install, not that it's too difficult, but there was a small mishap or two, but Ill get into that later.
Remove the motor cover (pops right off)
DSC00680.jpg~original
DSC00681.jpg~original
Unplug MAF, crank case breather and fuel pressure vent hose
DSC00682.jpg~original
DSC00683.jpg~original
Remove bolt that mounts stock intake bracket to the top o' the motor
DSC00684.jpg~original
Loosen Intake tube clamp on throttle body, remove air box lid, and pull it all off. (Make sure you've popped off the retaining clips that held the MAF onto stock assembly)
DSC00685.jpg~original
Remove the 3 screws that mount the Stock airbox (2 inside, one outside on back of it)
DSC00686.jpg~original
Install 3 Rubber Bumpers where the airbox bolts were
DSC00687.jpg~original
Install Rubber bumper on side mount where on mine the horn mounts to
DSC00688.jpg~original
*note, I put the horn on the inside of the bumper and fender, found out later, that was not to be the case, has to go between rubber bumper and new airbox.
Install filter mount and bracket
DSC00689.jpg~original
Install other bracket and mount into engine bay
DSC00690.jpg~original
DSC00691.jpg~original
Correct Horn Placement
DSC00692.jpg~original
Intake Coupling on Airbox side
DSC00693.jpg~original
Intake Coupling TBody Side
DSC00694.jpg~original
Remove MAF from stock massive intake assembly and install it on the new Intake
DSC00695.jpg~original
and nowwww the fun part:
KN provides 2 plastic vent mounts. Ones a 5/8"barb to 1/4" thread (crankcase breather), the other a 3/16" barb to 1/4" (fuel pressure vent hose).
Since I got the metal not plastic intake, and the metal is chromed, there's a little bit of fighting starting the plastic breathers. Apparently I'm Hulk with my hands, and somehow overtightened and it sheared cleannnnn off.
DSC00696.jpg~original
DSC00697.jpg~original
FML...its 8pm and a tuesday night. I live local to Summit Racing, but the guy there was pretty much useless and couldnt match it up. I run to home Depot, and find the correct replacement for the 3/16" Barb, but not the one I snapped, the 5/8"
I do however find a 5/8" barb to 1/2". Then add a 1/2" to 1/4" coupling, and then a 1/4" dbl sided threaded insert... Hokey, but gets me through till I can order the right thing....and they're brass and wont snap off with hand threading :ak472:
DSC00698.jpg~original
DSC00699.jpg~original
About an 1" longer than I'd like, but it worked and doesnt interfere.
Reattach the 2 Breather Hoses
DSC00700.jpg~original
DSC00701.jpg~original
Mount the KN Filter (this thing is gargantuan)
DSC00702.jpg~original
Mount the lid
DSC00704.jpg~original
Mount the engine cover
DSC00705.jpg~original
Ta da... So long story short, dont **** around with the plastic inserts, order the brass ones as soon as you order the intake. Otherwise, the whole thing looks great. Sounds gnarly, definitely more pickup on accel. I'll let you know about MPG once I do a full tank run.
Just curious but how is this an improvement? The stock air box was pretty similar and looks like a cold air intake already. The only real difference seems to be the shape of the filter. Does this mod actually make any difference?
Thanks for a great write up and pictures, looks neat and shiney, one quick question.
What made you go for the chrome intake, my "limited" experiance on air intake systems is that you want colder denser air into your TB not warm air. I would think the chrome intake would heat the air a little.
I have to admit though it looks nice.
They claim 13 hp, ill dyno it eventually here and see whats up. MPG was my main concern, supposed to get 2-3 more, and even 1-2 towing is huge for me.
As for impressions, definitely more responsive throttle, and a little more pick up? (could just be my mind haha)
Just got a full tank of gas this AM, Ill let you know the MPG as per my normal driving.
Also....gotta love the sound!
Bay...I hate the Chrome lol. It came either Chrome or Black Plastic, i wanted the metal intake, more Becuase I want to powdercoat it. Thinking a crinkle coat red like my old sti had on it, or a crinkle black. I just wanted to get it on for now and see how it did. If i didnt like the intake, I was going to try the TRD one next.
Sounds good I like the idea of the red crinkle coat. Post pictures when u get it done.
I like it. I may have to do this to my 5th gen like I did with my 3rd gen. Keep us posted on your thoughts over time.
ok so ran through 2 full tanks, one everyday normal driving (5 mile commute, typical errands and etc), half a tank on the highway and half a tank highway towing my enclosed, twin axle 2 motorcycle trailer. Getting 1.3-1.5mpg better driving round town (17 to18.5), highway is 2.0-2.3 (20.5 mpg to 22.5-22.8) and towing was kind of all over the place, was going to Nelsons Ledges Road Course which is half highway half hilly backroads but was getting 2mpg better on average... I"d say its worth it, and will only take a few months to pay itself off with gas savings (trucks 1.5 months old and already have 3k miles on it)
If you dont care/enjoy the sound of intakes, its definitely a good upgrade...but if you dont want the louder noise, just be warned its got a nice note to it!
Because the toyota engineers are going to try and eeek out every last mile of efficiency with the design.
Plus you probably are going to have a hard time light footing the skinny pedal. I know I do.
Guys when I put the K & N on my 3rd gen I wasn't concerned about MPG's to be honest with you. I just wanted to get more balls out of it and it sounds great when I get on it and other people wonder what's up too. I like it and I've had it on mine for 5+ years now with no issues what so ever.
I do like having the black plastic tube over the chrome though. Here are some pictures of the K & N on my 3rd gen.
http://www.cardomain.com/ride/2590536/1997-toyota-4runner#25905360012
http://www.cardomain.com/ride/2590536/1997-toyota-4runner#25905360001
http://www.cardomain.com/ride/2590536/1997-toyota-4runner#25905360002
http://www.cardomain.com/ride/2590536/1997-toyota-4runner#25905360016
Give it a couple of tanks more and I bet it will be the same as before or less
i would have to agree,
the CIA'S look sweet and sound sweet but i bet dollars to donuts that you didn't gain any hp .
i have been messing with my dodge ram cummins over the years and i have been on the dyno a couple times after mods and the BHAF (What diesel guys call CIA'S ) Didn't make on lick of differnce in HP but! It sounded sweet !!!
Just MHO .
Gary
