LawnDart's Build Thread
Lawn, where were you on those pics? That is a true sense of Oregon Weather, raining like a cow pissing on a flat rock... then just broken clouds and misty fog.
Up past Cascade Locks. I think Sunday I'm going to head out to the by windmills in Arlington.
Anti-Dark Kit installed...finally.
Wiring the light bar and rear flood lights
Sorry but no! Black is beautiful.
If you're in Portland come down to the Portland International Autoshow. My vehicle is on display!
BEAUTIFUL TRUCK!
[MENTION=124732]LawnDart[/MENTION] Getting back to an old question... Ive been looking through your build thread trying to find how you went about running your power cables for the Light Bar and Rear Lights (drilled a hole, along the windshield).
Wanted to get your take and experience from a personal build or shop performed installation.
Thanks again, your pictures are worth a-thousand words.
You're definitely doing it right.
BEAUTIFUL TRUCK!
We drilled two holes in the roof and ran the cables down the passenger A pillar, behind the airbags obviously, and then down and through the firewall. The holes were sealed using marine press grommets and some RTV sealant to ensure everything was water tight in the rubber roof channel. From there they went up to the roof rack and which comes pre-wired from the front to the back. In that photo you referenced you can see both wires on the roof rack between the rails and the top of the roof.
Hope that helps.
