LawnDart's Build Thread
i mean, while your OAF gotta look manicured lol. they make nice stuff, all i can afford is a shirt.
A friend of the company was like, "hey we had a bunch of titanium around, and were bored, we made beard combs out of titanium, want one?"
You do not turn that down.
This is actually done via a glass filter that causes point lights to streak out. Really neat filter that makes JJ Abrams pop a boner.
It's an awesome effect! Way better then 1980's laser looking lights painted on a backdrop.
:photo: :artist:
Truck goes in a week from tomorrow for stronger rear springs. This should give us a little more lift in the back, and allow us to raise up the front which should solve some small rubbing we're getting when down at 10psi (we don't rub at street pressures or above 18psi). Also going to sound deaden all 5 doors, install a few other bits, and wrap the hood scoop.
Little update on the trailer. We're getting the first delivery in March, and I think we've nailed down the configuration:
-CVT Tent (gray)
-Rigid Rock Lights and Bed Lights
-Baja Designs S2 Area Lights
-Nitto 35/12.50R17 tires + wheel spacers on Crager 8.5 rims.
-6' Fox Wing
-Warn 10K Zeon in Multi-Mount setup
-Switch Pro controller
The Prototype is all done. We're doing the Toneau cover but not the rear tire carrier.
I have some friends at Crye Precision, so it'll be wrapped in Multicam Black
Hey are you still running the odyssey PC2150ST-M battery?? Any issues with it fully recharging without changing the alternator? I am thinking of pulling the trigger on one.
I am, it works great. However every 1.5-2 weeks I throw it on the battery tender just to keep it in good health.
To clarify, the factory alternator does not put out enough power to adequately charge the larger Odyssey batteries fully. If you do not put it on an auxiliary charger or upgrade your alternator your battery will never get a full charge and thus shorten the lifespan of the battery.
The Odyssey batteries are also a little finicky on auxiliary chargers. They keep an approved charger list of known and tested auxiliary chargers on their website.
Correct, I run this:
https://www.amazon.com/gp/product/B000FRLO9Y/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
I put it on a charger every other week overnight.
chasebradshaw
