Dylan
Member
i got a 2005 sr5 4wd. I get a pic of all the hardware up, i just brought some new from toyota, and some refurbished oem.
Awesome! I look forward to the pic
here is the picture your hunting. this is OEM parts (but i had them chemi blacked) standard would be silver.
parts you need are assembled into the front joint, also i positioned another set next to it for clarity. you will need all loose parts shown. Per side of car. 90119-14120 $8.25 (just the threaded bolt)
Thanks for the info! I definitely have the wrong set and will be returning them. I just need to find all the correct part numbers for the front and rear cam assemblies and get them ordered.
#2,3, and 6 should be salvageable...save about $30
cant remember if i could save #6...it could potentially be saved depending how the bolt is cut and if there is enough bolt to possibly vice grip
A1 autos seem to be out of stock of their complette upper and lower control arm assy.
any leads on a good affordable source for these control arms?. the 1A autos assy was $220 for the 4 control arms, buying single units from rockauto is about $500.
I just ordered the Detroit Auto kit on ebay. I dont offroad or anything crazy, just a daily driver. Upper and lower controls arms, inner and outer tie rods, and sway bar end links for ~$200.
Upper Lower Control Arms + Tierods Sway Bars for GX470 4Runner NO Adaptive sus | eBay
am leery of DTA parts, bought their tierod assy last time, and the boots didnt fit, hole was too wide:target:
they have low prices though, did you compare them with the oem you changed out??
I just ordered them, they haven't been delivered yet. I'll try and remember to take pics when I get the stock ones out, assuming I don't have to cut the arms out due to seized cam bolts.
