LBJ replacement interval?
4flyer
Member
So, I know that it is important to not go on the original LBJs for long on our rigs.
My 4Runner is currently at 235k miles and is a southern truck with not a lick of rust. The LBJs were originally replaced at the dealer at 65k miles in 2005. Last time I was getting an alignment done, I had the shop inspect the LBJs and they said that they were in good shape. Now, we are approaching 200k miles on the LBJs. Should I go ahead and replace them soon or is there a suggested replacement interval? Thanks!!!!
It's very good insurance and a very easy job, so I believe the answer you'll get is a resounding yes (including from me!)
You'll probably hear this 100 times but I'll chime in anyways: My rig is at nearly 300K and had the original LBJs - I had them inspected during an alignment and they supposedly checked out. Checked it myself and looked fine. Changed them out maybe a month or two later and they were TOTALLY shot. The ball totally flopped around, and movement felt gritty. Opened the boot and saw yellow, water-logged grease. God knows how much longer they had in them
I recommend replacing them when convenient, but don't put it off. You're definitely due. Believe the interval was like 60K miles or something
like stated above, do them now. Its pretty easy to do and all the "special" tools you can get for free from Orielleys ( well rent and return and get all money back). Autozone did not have both I needed.
but its an easy job in most situations as long as things are not rusted to crap and stripped.
you want to torque correct. so maybe 3 tools to rent/borrow
From what I have seen OEM should be good for 200k change intervals on a stock rig used for highway and dirt roads(not mudding or water crossing), if lifted over 2" you're on your own and might wanna do it every 60k, the range of a stock LBJ doesn't allow much droop lifted beyond 2-2.5" and will cause excessive wear and even binding and separation due to the design. I wish these OEM LBJ would go down in price!!, but I guess we should be glad there available.
Yeah, be happy they're still produced. Toyota has already canceled production of certain odds+ends relative to our vehicles. Big one are the clear glass headlights, as you're probably aware.
I think checks should be done every year at minimum, but it's really hard to say what the replacement interval should be. I'm pretty sure lifted rigs will wear through these much quicker.
I had OE joints at 300,000 kms and they were still tight. I put on a 3" lift and after only 70,000 kms they needed to be replaced again as they were noticeably looser than the old set. I was able to directly compare them as I kept the old parts as spares.
all above is true and sadly the lower ball joint is a weak point on these rigs. I have owned cars with much worse maintain issues, so I guess this is not so bad. Luckily they are pretty easy to replace in most cases ( no rust etc) but seems like my last TOYOTA ones only went about 80k but I do hit some hard roads and I was slightly lifted. well I dont know how bad they were, the alignment shop said one was a little loose. So I did them both for safety and peace of mind. They both felt the same when off, so who knows. Brake downs out here are not good. I hit roads with no people or cell service for an hour at a time. I assume it would be the same on any WAY back road even in the lower 48.
Also using FSM testing for a few millimeters of slop is hard.
Just today, on the 3rd gen mafia forum someone posted a picture of today their failed ball joint.
( 3rd gen mafia....facebook)
Mine are still the original at 220k and they are still tight although I definitely plan to replace them soon.
Best to do them and get it over with, like said above its an easy job. I bought my runner at 197k miles and did them immediately despite them having no play as per the FSM procedure. Didnt know when they were done last if ever so it is cheap insurance.
Little known thing, Toyota did have a recall on some of them and still have a PN that contains both LBJs (cheaper). The PN is 04005-02235.
thanks, that does look lower than buying individually, does it contain the bolts, cotter pin, nut, etc ?
None of the hardware came with mine unfortunately which seemed odd. Youll have to order the bolts separately and mine did not come with castle nuts. I would get those as well for the few bucks they will be, still far cheaper.
I wouldn't know if Toyota has ceased production on the 99+ headlights, but you can still buy those headlights from Amayama...I just did.
Yeah for $200-300 each... The issue isn't that they're not sold anymore, the issue is you can't find them at a justifiable price.
for those thinking of LBJ's soon, 2 people today posted pictures of LBJ's failing TODAY. Both aftermarket. ON the facebook 3rd gen mafia page. 1 set was detroit axle brand, other person did not say who made his/hers.
Yes OEM are not cheap. Neither is the damage resulting of having any fail regardless if OEM or aftermarket. Ill use OEM in this application.
I just picked up an 02 with 147k miles. The LBJ were replaced by Toyota about 90k miles ago under recall, in 2005. The truck is impeccably maintained.
Should I just do them again or give them a bit of time?
Conventional wisdom: If you are lifted, yes. If you drive a significant amount on washboard roads and other high-wear 4WD road conditions, yes.
If just normal streets and highways, no.
I put new OEM LBJs in at 120K miles, when I acquired the 4Runner. At that point it had been driven 120K miles unlifted on normal streets, so the original LBJs probably would have lasted another 100K miles. Now the 4Runner is lifted and it's done a couple thousand miles of rough roads. I'm now at 178K. I'll do them again by 200K miles.
I wouldn't change then unless the steering on the 4Runner isn't floppy and if there isn't much play on the ball joint. They still got a lot of life left. I would change them at 190k again with original Toyota parts.
Congrats on the low milage find, harder n harder to come by.
90k mi on LBJ's I'd start by doing the FSM inspection to determine the condition of what you have.
I do FSM inspection every tire rotation, its easy once you get the hang of it.
Going on milage alone 100k mi I'm changing them, got my money's worth.
I've seen LBJ separation on net, sunk in when I saw it first hand in Lowes parking lot,
Father n young son 2 blocks from I-55 & 70 mph.
AndiGarage
