Leaking oil while parked facing downhill
Ok, so it's wet up top and back of block. There are 2 areas on the 3.4 rear of the heads that can leak besides the vc gasket. One is the half moons (both heads have them on the back) they are a half circle that seals a machined part of the head, known to leak due to heat expansion and breakdown of the sealant (use silicon or toyota fipg). Two, there is a cam plug on the drivers side head at the rear, it is a metal plug (like a freeze plug) with a rubberized coating that can leak with age. Replace with new one with some silicon or fipg on the outside edge.
Both of those can leak down into the bell housing and cause it to leak only when parked downhill. It's a PITA to see back there but you can with a flashlight and a small mechanics mirror. Check there for the dye too. Unless the previous owner cracked a Valve cover doing gaskets. Or he did gaskets and forgot to replace the metal/rubber valve cover bolt washers.
But still doesn't explain the oil on the starter/alt white plastic cable cover. Could it be power steering fluid? I know the 4runners use atf, but some use a clear ps fluid.
Seems odd that everything is leaking. My 2000 3.4 245k miles and the front main seal was dry as a bone (still replaced it when I did the water pump). All other seals besides the oil pan and rear main seal are pretty easy.
I'd do 100 3.4 vc gaskets , cam seals, half moons, front main seals then do 1 v6 vw passatt vc gasket and cam tensioner any day lol.
Oh yes if you do decide to tackle the half moons be careful to not get old sealant into the oil return holes. Cover the area with rags or something.
Holy smokes I rambled on. Keep us updated. This may have not been asked, but it isn't your clutch slave cylinder that is leaking is it? Driver's side lower bell housing. Did a friends 4runner 3.4 manual clutch slave cylinder that finally kicked the bucket at 378k miles, fricken original clutch too!
Another update: parked uphill leaking much less but there's definitely coolant dripping off the oil pan, it wasn't lighting up under the UV light and upon closer inspection it's definitely green. Looked in the radiator and it's completely full so I'm hoping it's just some excess leaking out of the overflow reservoir? It's not a huge leak but it's definitely coolant coming out of the front somewhere.
Sent from my SM-G970U1 using Tapatalk
Doesn’t sound like the engine on that rig was maintained very well.
Coolant seeps up front tend to be water pump failure.
As for the oil leaks. Remove the skid plates and then clean the engine and front running gear real well with degreaser. It’s probably easiest to go to one of those do it yourself car washes with a fist full of quarters.
Then once it’s all clean you can drive it a bit and then inspect for leaks. Leave the skids off till you find and resolve your different leaks.
So is it a coolant leak or an oil leak or both? For the oil leak in that area I'd like to mention an area not mentioned - the oring on the end of the oil dipstick tube. Spray some brake clean and get it dry and powdery then park on your hill. For the coolant leak, There really should be a white trail somewhere. And as with all leaks, try to find the "highest" and most forward wet spot in the area you see the oil or coolant accumulation.
EDIT: I read your comment a few more times and it sounds like you feel it's coolant. As I said, there should be dried whitish build up where it leaking from. WP weep hole or gasket, upper and lower rad hoses and where they connect to the motor, coolant hoses going to the IAC under the throttle body, the radiator itself with the coolant blowing back on to the front of the motor.
When you were parked facing down hill was the runner also leaning to the passenger side? The reason i ask is because i had a leak the same condition of yours, and found it was the brake fluid reservoir cap leaking and ran down the motor. Only did it when i parked facing down hill.
I parked my car down hill . Car facing down hill. Noticed brake resorvior cap leaked fluid.
Did you just replace cap? It it solve problem?
