Leaving AC on when turning off engine?
08t4rUR
Is there any harm in leaving the AC on when you shut the vehicle off? Does the AC clutch automatically release when the engine is turned off?
My '03 shuts off the AC but leaves the fan running when the engine is off. Shouldn't be an issue.
Do you mean you are turning the engine off and letting the ac running on the accessory setting on the ignition? If so, no harm except no cool air will come out and you can run your battery down.
I live in the wet Seattle area so I basically have the AC on 24/7/365. I never turn it off and have never noticed an issue in my Honda or 4Runner.
Same here but in humid Louisiana. I have never turned the A/C off in 30 years of driving, even when the temperature is turned to heat during the winter. Never had a problem with any vehicle, mostly Toyota.
I know a few people who do this (turn off the A/C before turning off the car) but non of them have ever been able to tell me why. Its always just because that is what their parents did. I never turn my off other than the winter.
Edit: So from my 2 min of research on google it looks like its 1 of 2 reasons why people turn them off. It's either from the old days before cars could disengage the A/C until the car was running causing undo strain on the motor/starter or some do it thinking that it will dry out the evaporator and that in turn will not let mold grow that gives you that nasty smell.
I leave 8t on all the time when it's hot, having it on when I remote start my truck far away let's me have a cool inside after all that walking. Also nice to leave it on heat when it's cold out too.
Thanks for all the responses. A friend of mine was riding in my 4runner last week and noticed that i left the ac on when i turned off the engine and said that it is not good to do and i had never heard that before so, i thought i would ask.
That's why I do it. I had that nasty/moldy smell in my old Subaru, took spraying a couple of cans of Lysol into the air intake to get rid of it. After that I got into the habit of switching off the AC a few minutes before shutting off the truck, this allows the ducts to warm up to outside temperature so they don't get condensation in them.
It's not a huge issue here in CO where it's dry, in areas where it's more humid I'd be more concerned.
I'll agree that it's probably not necessary anymore - seems like manufacturers have figured this out and this doesn't seem to be a problem for most people, but I guess I do it out of habit more than anything else. :shrug:
Lmao, I almost posted this exact question in the 5th gen section today. In my mind, it's easier on the motor to start it without the a/c clutch engaged. The truck probably does that on its own but it doesn't make a difference in how quickly it cools down so I just leave the a/c off until the truck has been running for a few seconds. It's like people that turn their headlights on and then start their vehicle... never understood that.
Tell him to mind his own damn business or get somebody else to drive him around next time.
Having the AC off before starting the engine lightens the load when starting. Newer vehicles may (or may not) temporarily disable the AC when starting, over the years I've learned to turn the AC off before turning the engine off.
I know my 3 80's trucks won't do it, my 2000 Trooper maybe, and the 2010 Sonata probably.
And I'm moving this to the General discussion section.
This is exactly what I was going to say. The only reason people used to do it was the strain it put on the initial starting of the vehicle. So it did make sense back then. . . nowadays not as much of an issue
I turn it off by habit and it was to prevent the moldy smell in older cars. Plus if I leave the A/C on my belts squeal like crazy for about 30 seconds when I start it. I read my 3rd gen turns the A/C on when you run the heater to dry out the air.
My vehicles make a pronounced "click" a couple of seconds after the engine is running. Some have auto climate control and some have the old school turn the knob and adjust the fan style.
The "click" is the sound of the air compressor clutch engaging. As for the musty smell of the vents, There may actually be another reason for the smell like a plugged drain line that won't let the evaporator drain off.
I've driven cars for years in the hot and humid south and never had a car with the musty smell. If your vehicle has the damp musty smell, I would look closely at the drain lines first.
Your friend wouldn't happen to drive a Colorado truck would he? I've heard from a couple owners that leaving it on burns up a relay or something of that sort. May be the same case for Tacoma's too. It's just hearsay so take it with a grain of salt. I have friends with one of each of those and they had to go in and mess with something with the AC to get it to work properly again.
delislerebecca
