blarblarjosh
The other day i installed the Eagle Eye LED tail lights and since then I've been having a bunch of weird issues with my lights. Just because I know LEDs sometime cause issues else where here's a list of everything I have done (that I can remember anyway):
When I first installed the tail lights I had the infamous ABS light trigger so I went ahead and replaced the 3rd brake light with a regular halogen bulb. That fixed the problem for the most part, but once in a while it would turn back in. At the same time I also noticed that when in drive and only drive my head unit acts like I have my head lights on and dims itself. I've since found that when pressing the brakes and turning right it caused my clock to flash bright and dim where the dim acts like my head lights are on.
To try and rectify this I went ahead and installed some 25W 6Ohm resistors on both tail lights. Rather than fixing anything though it seemed to have made things worse. Now when I signal right my dash lights and the shifter lights blink with the turn signal as well as the clock. I got out of the car with the right turn signal on to check and see if the switch back was still flashing amber with the turn signal and it was, but I noticed both corners were flash as well. I don't believe this was issue before hand but I could be wrong, didn't want to pull out the resistors yet to verify.
Anyone have any suggestions on where I can start to try and fix this? I don't have my old tail lights anymore and would hate to have to buy new ones to replace these out since they are brand new so any suggestions would be appreciated. Thank you.
- Dash Lights
- Dome Lights
- Switch Back Halos (part of a 35W morimoto HID retrofit) spliced to the turn signal
- 3rd Brake Light
- Corners
- Reverse Lights (tapped for my back up camera)
