LED interior lights
I ordered JDM Astar they just showed up today install was breeze just make sure you have the right tools. they are about $10 cheaper on ebay then their website.
how to remove your bulbs video :-
https://www.youtube.com/watch?v=gjrLVdOaEhQ
dome and rear gate ( need 3 bulb ) :-
JDM ASTAR DE3175 31MM Error Free 18 SMD Map Dome Interior LED White Lights Bulbs | eBay
map/lic plate/ door panels qty 10 :-
JDM ASTAR 10x T10 Super White EX 24-SMD LED Lights Bulb 194 168 175 W5W 2825 192 | eBay
Can you confirm the linked bulbs work with 5th gen? I had my 2017 Prorunner typed in and it says its not compatible.
Bringing this thread back to life. I didn't see these lights I used listed. Changed all lights for $17.99. A lot of the links in this thread are broken, or not listed anymore.
These are the 2 front map lights, 2 vanity, 4 door lights, 2 license plate LEDs.
https://www.amazon.com/gp/product/B01DE7UC6C/ref=oh_aui_detailpage_o04_s01?ie=UTF8&psc=1
Some have reported flickering with the JDM's after a period of time. I had them in an FJ, and Tacoma w/ no issues. Luck of the draw I guess.
These are the 2 rear hatch, and rear passenger dome.
https://www.amazon.com/gp/product/B01M0X7X1M/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
How do these compare to xenon depot or precision LED? Are they worth the premium?
Did you change all lights for $17.99 or $30.98?
I've added them to my cart and the total is $17.99 + $12.99 = $30.98
i got all my LEDs from firefly, came with everything including the puddle lights for the mirrors.. so far so good and extremely bright!!
White LED interior lights package kit 2016-2017 4Runner 15 pcs 3014 series SMD | eBay
I just tried the ebay link - it says it works for 2016 and up 4runners. When I input 2014 4runner LE it says it is not compatible- I didn't think anything changed between those years - so safe to assume this will work on 2014 also?
Edit - I msg the vendor - he said the bulbs will work on 2014 as well as expected. I just started looking into the interior Bulbs - what makes this set better than the cheaper ones on ebay or Amazon?
Just an FYI Morimoto is also doing LED small bulbs now. Gold plated connectors and ultra bright. I run them is several of my current Toyotas. Amazing.
That's interesting. The price must have changed. I just looked at my Amazon orders, and the oEdRo lights were $4.99. Looks like they've increased the price significantly.
Does anyone have issue after swapping map lights from halogen to led? With original bulb the map light would dim after a few seconds and then go completely off. With LED it dims to barely lit but will never go completely off unless I manually switch it to "off".
Does anyone know what brand or the company that supplies the bulbs for the Southeast Toyota region. Interior LED lights is a port installed option. I would assume those could be the best option to go with.
I know AUER supplies the outside LED foglight and 2 in 1 but they do not supply the interior.
erinobr2000
