LED lights.
Utopia
I am looking at Precison LED light package for $61. Is that a good price? Includes 4 dome, 4 courtesy, 1 trunk and 2 map in 8000k cool white. Any
Other suggestions? I vaguely remember reading that a member on here sold them, but I may have been dreaming too
Got dome, map, courtesy, rear compartment, license plate, and reverse for $21 free shipping on Amazon! Don't over pay! Lol
Just ordered these lol thanks.
Please let us know your thoughts and impressions once installed. I've been using the old for years, so I'm not missing anything as I'm used to what I have. However, for 15 bucks I might need to try what I don't have?!?!?
You should just grab them. It's actually a really nice and noticeable upgrade.
Unfortunately even LED bulbs can be cheap and not fit correctly.
I purchased some eBay LED bulbs last year for another car and they both fell out of the socket of my taillights. Luckily I was able to take the taillights off and move the taillight around to get the bulb out. Replaced the bulb with one from Diode Dynamics with much better quality, fit is perfect.
Ordered mine today. For 15 bucks to replace all interior lights to LED almost seems to good to be true. However, I have 2 burnt out lights so I don't have much to lose, but brightness to gain!
Hoping to install next week during kids spring break!!!
I was trying to save the money, but you guys keep bumping it and then I realized my hypocrisy when I was telling another member to just buy coilovers since it's only money, haha.
Ebay says they'll be here monday!
Did mine for under $20 from Amazon and they look great.
Next up? Complete exterior lighting dash and console re-do with led's from Superbrightleds.com
just have to do an inventory on quantity and colors needed.
I have installed them too, excellent upgrade!
Just don't touch the Vanity mirror Light!!! I've tried to replace that with 3 different types of LED's and it blows the fuse every time!
I swapped my stock bulbs for LEDs a while back. My 4Runner is a 2007 Sport. The following information may be helpful but I make no guarantees and your experience may vary:
- Take the opportunity to clean all the lenses inside and out while they're off. It can make a surprisingly big difference in brightness.
- Polarity matters with LEDs, so if a bulb doesn't work, remove it, rotate it 180 degrees and plug it back in.
- Turn the switches on the dome and cargo lights to OFF while you put in the bulb. I didn't and blew the fuse.
- The door panel light housings can be gently pried out with a small flathead screwdriver. Once the housing is out, the lens is easy to pop off. But for the dome and cargo lights, put the screwdriver blade between the lens and the housing and gently pop off the lens only. The whole housing doesn't come out.
- Once the lens is off, the best way I found to install the dome and cargo bulbs was to gently grab one of the metal ends with needlenose pliers, put the other end up into the socket, then push the end you're holding up into place.
Hope that saves somebody some aggravation.
Wow...these LED's arrived early and fast. With that said, they are stuffed in a sealed baggy. I'm hoping to install later today!!!
