brennansalazar7
LED illegal or HID?
Halogen doesn't hold a candle, watt for watt, to HID. You'll be shocked by the differenceHow about some really high end halogan and then I won't have to make any adjustments? What type would you recommend?
Howdy, it's a very simple project, took me a few hours. There are several ways to do a retrofit. There are better projectors put there, but for something to get you started, this is hard to pass up. It's also very simple in that it required no modification to the headlight itself, other than paint if you want. Here's my build thread, lots of pictures in there and if you read through a little further there are some links and a ton of information. I wish I would have done this a long time ago.
http://www.toyota-4runner.org/3rd-g...-mothra-budget-camping-rig-5.html#post2675021
Hi! Can you please let me know if this HID kit could be used for this project? Thanks,
No, if you buy the one I put in the link, it comes with everything you need. The bulbs that the projector use are H1 bulbs. The harness from TRS you will select H4
Ok, this is my selection, it's ok?
Yes, I'm not sure you'll need any sealant, I didn't on mine. 6000k will be a light blue and 4300kbwill be pure white. I really prefer the 5000k, but I'm guessing they're sold out.
I highly recommend 4300k over 6000k, as they have more lumens, not to mention a more pleasing color (subjective).
Also, I recommend 3" projectors (D2S) with 55 watt ballasts.
good question. I can't answer it but i hope someone can!Just wondering, can I just turn on the LED light bars on the bumper and roof rack when I get them installed when I need more light? Will this achieve the same result? I guess the problem is there will be no upper cutoff so you'll blind oncoming traffic. Could turn them on and off like high beams depending if there is traffic. Is it illegal to drive down the road with LED light bars on?
Very much so. A lot of people do it anyway, but they're dicks.Is it illegal to drive down the road with LED light bars on?
I was just thinking this. It's the only way to maintain the original beam. I get my harnesses from Susquehanna Motor Sports(rallylights.com).If you're keeping the stock housings, a nice higher wattage PIAA halogen with a relay harness is your best option.
The 3" MD2S is no more difficult to install than a 2.5". Not sure why you would recommend against it.For a simple retrofit for a beginner, the 2.5" kit linked here will probably be the best bet.
Thanks, absalom! Could you please let me know why you recommend 3" projectors (D2S) with 55 watt ballasts? Actually I have this HID 55watts on my headlights and want to know if this can be used in conjunction with the 3" projectors.
Mine were incredibly easy. I didn't cut or trim anything- other than the shroud.
I take that back- there was a little nub on the inside of the reflector- where the projector rests against- that I clipped off in order to let the bowl sit flush against the housing. But that should be done with any retrofit, so it's really irrelevant.
I retract my statement then. The only D2S ones I had seen required major surgery of the housing.
