LED replacements for clock & A/C control backlights?
Bolderboulder
Are there LED equivalents for these small bulbs that backlight the clock and A/C control buttons? The dealership wants $6.50 for each standard replacement bulb!
90010-09017 : Two required
90010- 09015 : Two required
90010 - 09016 : Two required
Not sure about LEDs but the OEMs are 6 volts bulbs and I don't think you can get 6 volts LEDs, you can however do a 12 volt conversion on the control panel to replace these 6 volt bulbs with 12 Volt bulbs and then possibly use an LED. (do a search on the forum).
As far as cost of OEM bulbs, you can get them fro around $4.50 each from some online dealers and or eBay.
Thanks! I think I will just stay with the OEM bulbs.
erinobr2000
