LED turn signals
a t l a s
Has anyone had any success finding good quality LED turn signals with built in load resistors?
There are a few that I've come across that look like they work fine, but are 1000-2000 lumens which is insane for a turn signal. I am not trying to blind people.
Diode Dynamics has a few different LEDs ranging from ~250-500lm which make more sense, but they do not offer LED bulbs with built in load resistors. I'd rather not use splicers on my factory wiring.
$160.00/PAIR
Holy Jesus' Resurrection next week. For turn signals?! Ya'll have too much money.
10% off right now. Also worth the cost when the face of the person behind the entire car in front of you lights up in amber so they know where you are going. It's definitely needed here in Derpifornia.
True, but I've always though the rears were fairly bright. However, I do like switchbacks for the fronts.
I used these form my rear
7440 7441 CAN-BUS Anti Hyper Flash LED Turn Signal Lights, Amber Yellow - Lasfit Auto Lighting
And these for my fronts
7443 7444 CANBUS Error Free Dual Color Switchback LED Turn Signal Light - Lasfit Auto Lighting
They are super bright, but they work with no hyper flash, no bulb out warnings and no need to tap any wires with resistors. They can be found cheaper on Amazon and Ebay
I highly recommend them
Will any of these non flicker led options being given work for the turn signal/DRLs on the 2010-2013 models without fear of overheating if in DRL mode?
^THIS
LASFIT is the best of all the light brands I toyed with, I took 97BlackAckCL recommendation and I'm very pleased with them. On the preface 2012 the front amber DRL/turning lights really are bright but when I signal they are very noticeable. It give is that JDM appeal.
Did you get the Standard socket or CK socket for the front turn signal?
$160.00/PAIR
LOL!
On our first-gens we just modify the blinker module or replace them with plug and play after-market ones that work with LED's
Really? After 35 years, 4Runners still don't have a blinker module that accommodates LED bulbs?
I really like these Lasfit LED’s, easy install, no splicing or resistor needed.
Reduces the amber in the housing when not on
Parking light mode
And they’re the brightest when Turn signals are activated
I'm running these and can attest that they work really good. Bright as heck and plug-n-play
DJNutshell
