So I was curious if it's possible to turn the top plate of the strut assembly to keep the XREAS tubing in line with where it's supposed to be?
As in compress the spring, turn the top plate the appropriate amount and release the springs.
I have XReas and added 1/2" front spacers for a 1" lift. No turning of the top plate was necessary and I don't get why you would. The only time you would have to rotate the top plate 60 degrees is if you used spacers with staggered bolt holes. For the thin spacers they just bolt right in, although of course you have to fit longer studs.
The XReas hydraulic lines come into the bottom of the shocks so they aren't in your way one way or the other.
