Lift and Tire Central (pics)... Post 'em Up!
Are the OW kits still available? I was reading up on them and the ICON kits and I remember seeing a thread about them going out of business.
Unfortunitely OW did go out of business but ou can buy the Radflo suspension product built to the OW 2.5" HD specs.
Had a little fun on the 3rd day of having the new shoes.
The Walmart tire! I've always thought they looked promising but was turned off by the fact that it's exclusively sold at Walmart (if I am thinking of the correct tire)
yes those are walmart tires, but there are two version of these tires, class c and class e, I got the class e which is the heavy duty version, but really for the money you cant go wrong with these tires, and so far no complaint.
Nitto Terra Grappler 265 w/ 17in XD Addicts
Replaced the stock wheel/ and spidertraxx spacer with the new setup.
Before -and after
XD798 matte black 17" Nitto TG AT 265/70/17
right now, rubs like heck turning.
Getting a daystar leveling kit - hope that helps with the rub.
Chris
Before -and after
Chris
Looks great, wheels look very similar. Maybe they rub because offset is too low? I have 17x8 with 12mm offset, and same size duratracs, no rubbing at all
Those wheels and tires look great. The rubbing is probably a result of the slightly larger tire and wheel offset. What offset did you get, the -12mm or the +18mm? I am guessing the -12mm. I wouldn't have thought the +18's would rub with that size tire. I think the stock wheels with Spidertrax are an equivalent -1.7mm offset. The lift will help, you might still need to do some trimming on the front fender area. Lift it and see.:thumb3:
