Lift and Tire Central (pics)... Post 'em Up!
i am running spidertraxx and just the 1" spacer that netted me about 2" of lift up front. i put on 265/65/18s and rubbed the mudflap and fender liner. i moved the fender liner forward and ended up cutting the mud flap in half to clear. you can't tell anything has been cut or moved when looking at it.
with your lift, you may just rub the liner and need to move it forward a bit. that takes all of about 5 minutes per side.
Thank you, and thanks everyone else for your advice!:usa2:
255/75/17 will fit with minimal rubbing on the 2.5/1.5. once you add the wheel spacers and move the wheel/tire outward, it will more than likely contact the fender well and mudflap more
I have this exact tire size with no lift and ABSOLUTELY NO RUBBING AT ALL!!!
Now, if I add Spidertrax (which i plan to) it may rub a little. As far as i can tell, the 255/75r17 is the largest conventional tire size that will fit without rubbing. Each tire wont have exactly the same diameter, even with the same "size"...but my Firestones are considered 32.1" whereas the Duratracs are a 32". Yes, small difference, but a difference nonetheless.
265/75/16 duratracs w 16" FJ TRD 6 spoke wheels (no center caps)
stock sagging suspension w 105k on it
Nothing special. Just put on some Sport wheels and SpiderTrax.
Before: 16" Tacoma wheels w/ 265/75/16's.
After: 17" Sports w/ 265/65/17's and 1.25" Spiders.
Just picked this up. It has a Toytec 3 inch up front and Superflex 2 inch rear springs. Tires are 285/65-18
They rubbed a bit in the front while pulling into a steep driveway somewhat quick with the wheel cranked.
Thought I made up my mind with tires to buy and then I see that you have the LT version AHHH!!!
TOYO AT II P285s VS. LT285s
Thanks to bthbama and jsmith21 for help on my questions, and huge thanks to everyone in this forum...I've been jealously reading it for almost four years, and I've finally done my mods!
While I have the Daystar installed now, here are pictures from before, just to compare stock suspension, but with different tires. 4th gen SR5 wheels, no lift, no spacers
Stock, Bridgestone Dueler H/T 265/65/17:
255/75/17 Duratracs. Really emphasizes the factory rake, but I had no rubbing at all.
Toytec Boss installed last Saturday. Adjusted Yesterday. Aligned and ready to roll this morning.
So I'm looking into getting about a 3" lift for my 02, what exactly would I need? I was doing some searching and found that 7 wrap LCs are a good spring, but I think I should be lookin 4 new shocks and 4 springs. My budgets around $600 any suggestions? :smile:
Check out the 3rd gen section!!!!
New Bfg T/A K02s now installed. Love them!!
<a href="http://s133.photobucket.com/user/05YZ250/media/Mobile%20Uploads/2014-11/20141111_143827_zpsdqkfrye3.jpg.html" target="_blank"><img src="http://i133.photobucket.com/albums/q79/05YZ250/Mobile%20Uploads/2014-11/20141111_143827_zpsdqkfrye3.jpg" border="0" alt=" photo 20141111_143827_zpsdqkfrye3.jpg"/></a>
275/65r18
275/65r18
Those do look better than the original style. Congrats
Ive been waiting for actual pictures of the new bfg a/t. it looks awesome! ive been waiting for these and the new toyo r/t's to make my decision. i do like the look of the new bfg's. i can tell you this. my nittos have the scalloped biting edges and man that particular function works friggin awesome.
REE
