Lift and Tire Central (pics)... Post 'em Up!
Looks good man! I can't say enough about the Hankook tires! I just put my stock ones on cause my BF Goodrich SUCK! I can't believe how much better the Hankook's ride and grab everything! My Hankook dynapro MT's will get here Thursday and the bf Goodrich crap can go on the garbage. Lol
Make a build thread. Always fun to show off and get ideas from everyone.
Yeah those were the ones I was more leaning towards... Also good idea... I'll start one uo
My body mount is unaltered a I've run 285's for a while before I went to my tall skinny tires. The true test will be to see how my truck fits the 34.7" tires I have my eyes on
How much trimming is that going to require though? I had read that 285's needs the body mount chop...Is that right?
Never had any issue's with them rubbing the body mount either. I have 1.5" spacers too. I suppose a wide meaty tire "might" touch them, but it's doubtful.
I rubbed. I had to trim my bumper, inner fender and my body mount. I went ahead and did the full chop since I was cutting already. I also have my caster maxed so that plays a part. I also only rubbed backing up and in instances when my wheel was stuffed while turned. Its really easy.
no amount of work is greater than having to look at your truck day in and day out thinking....dam my tires look small!..
hahaha you make an excellent point!
god I cant make up my mind....ill probably just go for it and and hope for the best
Daystar 2.5/1.5 leveling, & DuraTrac 255/75R17
It won't be my final solution, but I needed new tires, especially for winter, and I wanted to ease into the decision of what suspension components I'd eventually want. I recently switched from a Jeep XJ, and when I lifted that I loved certain things about it, but hated some of the effects it had on ride and handling. Because I REALLY like so many things about the T4R's stock handling and ride, I'm very hesitant to make major changes quickly, so I opted to go "cheap and easy" for now. Ya'll are an incredible resource, but reports on things like ride characteristics are too subjective to depend on. With my everyday use of this vehicle I can't afford to be dealing with too many unintended indiosyncracies generated by my need to mess around with things. (I need a spare vehicle? for when this one is getting kinks worked out :nod:)
I wanted to stay below the lift threshold that risks snowballing issues with suspension, spacers, steering, and drive-train; plus for tires I tend to lean toward tall-&-skinny, at least for winter. So far, so good, and I'm rather pleased with the way things turned out; and looking forward to making more permanent suspension changes in the spring with new wheels and summer tires.
Also changed swaybar bushings, and will be working on extended quick-disconnects in the near future.
before: (stock with 265/65R17)
and after: (2.5"f/1.5"r spacers, 255/75R17)
It'll be getting about 1000+mi added to it next week, including what just hit Buffalo NY, so... good test.
It seems an unpopular view, but I will NOT be removing my running boards before spring, and may never remove the splash guards. I've lost too many vehicles to rotted out rockers and door sills. I like this truck, and I'm trying to make it last. The new RCi front skid will replace the stock (dead) one as soon as the paint dries.
Waiting for them to be mounted. Using tire beads too balance them.
<a href="http://s133.photobucket.com/user/05YZ250/media/Mobile%20Uploads/2014-11/20141111_143827_zpsdqkfrye3.jpg.html" target="_blank"><img src="http://i133.photobucket.com/albums/q79/05YZ250/Mobile%20Uploads/2014-11/20141111_143827_zpsdqkfrye3.jpg" border="0" alt=" photo 20141111_143827_zpsdqkfrye3.jpg"/></a>
275/65r18
What do you think of the ko2's so far? Any negatives to the load E raising? What lift? Rubbing issues?
03 4runner
Here is my 03 4runner with a 2.5' daystar leveling kit in the front. Finally managed to get some new General grabber At2 mounted as well as 16' MB TKO wheels.
275/65r18
Do tell us more! Rubbing? Lift? Wheel spacers?
2.5 OME springs
1/2" front spacer
Bilstein struts
Old 265/70 R17
New bfgoodridge all terrain KO2 275/70 R17
These tires DO RUB in full steering lock on the front inner frame and the upper control arm. I will need to source 1" bolt on spacers to avoid. They do not rub the fender liners or mud flaps.
wayblom
