Lift and Tire Central (pics)... Post 'em Up!
Bilstein 5100s with daystar front 1" leveling kit
Toyo Open Country AT2 265/70/17
Slight rubbing at full lockup in reverse but I haven't messed with the fender lining yet.
I think the front and rear are about even but it kind of gives the appearance that the front is a little but higher. I am going to mess around with the height adjustment on the 5100s to see if that makes an difference. If that doesn't, does anyone know what would be the best way to get about a .5" lift on the rear? Is there a spacer or some kind of springs I could throw in there quickly?
New wheels and tires
Rancho suspension front. Spacer in back on OEM.
Sumitomo Encounter HT. 265/70 . 2018 TE Wheels.
Is anyone running 275 70's with a 3" lift on Sport rims? Thinking this might be happy medium between going up to 285 but up from 265.
05 SR5 2WD
Bilstein 6112/5160 w/ Icon 2" rear coils installed 2 days ago
Ordered Falken Wildpeak AT3W P285/70R17 last night to mount on SCS Ray 10's.
Thinking i should have gone 1.5 rear coils to have it more level.
got my 4runner more to where i feel comfortable sharing pics. :nod:
set up is,
Front-
Icon 2.5 coilover (non-res) w/ 650lb springs, dirt king upper control arm with heim joints, body mount chop, Wheelers superbump bump stops
Rear-
Metaltech medium long travel springs, Icon 2.5 long travel shocks w/ external resi, 2.5 inch rear bump stop extension, Wheelers superbump bump stops , cali fab upper and lower links
wheels/ tires-
17x8.5 +6 BMF SSD w/ rock rings, 1.25 spacers on all 4 wheels, falken wildpeak M/T 295/70/17
set up is,
Front-
Rear-
wheels/ tires-
17x8.5 +6 BMF SSD w/ rock rings, 1.25 spracers on all 4 wheels, falken wildpeak M/T 295/70/17
Looks good. Trimmed the front bumper?
I have finally put together my ideal 4Runner package. Obviously, more mods to follow but I got some big ones out of the way.
New:
spidertrax wheel spacers
Daystar 2.5"/1.5" spacer lift
BF Goodrich A/T KO (275/65/18) tires
2011-02-26_15-55-26_62.jpg~original
2011-02-26_15-56-15_502.jpg~original
2011-02-26_15-56-34_431.jpg~original
2011-02-26_15-58-49_197.jpg~original
First off, nice win against my Heels yesterday. I'll have a similar set up as you in a couple weeks and was wondering if your set up rubbed.
You have a great setup. My set up Toytec Boss set to 2.5", Spidertrax 1.25", Total chaos UCA, and considering 275/65/18 instead of 265/65/18 on the same factory limited 18's as you.
Did your setup require any trimming, removing of mudflaps or pushing forward the front fender liner?
lift kits and pricing
i am very new to upgrading my 4Runner. Any recommendations on different lift kits. I would like about 2" of lift but also the vehicle to be level.. Also, an idea of pricing would be nice so i don't get screwed over. Any recommendations would be appreciated.
If you want level, I can do a 3/1 for you like I did for this customer:
Can do any size you want
4th gen lift & leveling kits at Burtman Industries, ON SALE
290264d1521654143-lift-leveling-kit-holiday-season-sale-d8c347bd-d273-4062-8452-4f65ab26f879.jpg
More pics in the thread here:
http://www.toyota-4runner.org/4th-gen-t4rs/229041-lift-leveling-kit-holiday-season-sale.html
I would go ahead and switch out your suspension before doing a spacer lift. A lot of guys, myself included, installed a spacer lift to level it out only to switch out to a suspension lift later. You should check out the BOSS kit at Toytec. They also have the line of Icon kits.
Before and after pics. Installed daystar 2.5/1.5 inch lift/level, trail edition wheels with 285/70 17 Nitto trail grapplers. No spacers, still have mud flaps and no cutting required. Love it so far
set up is,
Front-
Rear-
wheels/ tires-
The fancy dual spring rate metal techs?!
DJNutshell
