Lift Installed
help kdss lean
Hey i was just wonder is your 4runner have one inch to the passenger side lean cause my have the same measurement as you on the driver side but on the passenger side is an inch lower on the rear and 3/4 inch lower in the front passenger. if you did how you fixed it. Running out of option try everything from opening the valve bouncing like a monkey on it doesnt work even take it to lexus dealer tech cant figured it out either need help.
prepair for burning - que in 3 2 1.....
There is tons of options, before having someone explain all of them the best thing to do is go to the lifted pictures and just look through them. Most of the people have what lift it is in there signature. After getting some ideas then check out the makers website.
Most have Toyteclifts.com Ultimate lift, others use Icon, only a few have OME.
This is exactly what I needed to hear. Going with the toytec ultimate lift.
This was an old thread! I'd say its about even now with toytec (lowest maintenance of the c/o), Icon, Radflow, OME. I'm going with toytec because people still have problems with hearing the other Coilovers make noise and that would drive me nuts.
All are fine, just pick your flavor. Remember 95% of these have to be daily drivers. So spending 5-6k on a stage 5 kit might be a bit overkill.
