Lift kit installed , rear sits very uneven ... Help
Make sure that the bottom of the coil is rotated so the the tail of the coil is seated in the notch.
Before installing, I made sure the longer coil went to the driver's side and that the coils were properly seated. Still no dice. Anyway, hard rubber spacers are an easy fix. I think Ill add a thin one for the passenger side and a thicker one for the driver's side, since the coils are basically sitting directly on metal. Im betting it will give a tiny bit more rear lift, some dampening benefits, and it fixes the uneven stance. It should work. :D
Me to. Just placed the coiled on the flat side on flat concrete sine by side. Put taller one on driver side. Driver side lean is very common on 3rd gen and probably every truck. Battery, steering components, gas tank.....
Bunkstaff
