slowteg97 said:yea cj i can do that for you and the ride is still the same no change.
falls not to jump all over your shit but gig did say he has a 1in spacer. and if you look at his measurements compared to my starting measurements you will see the spacer gave him 1in of lift and the remaining hieght gained was from his tires and since i used a 2in top spacer and gained exactly 2in of lift in the front i feel its safe to say that when using top mount spacers the size you use is the amount gained. so far its been proven twice.
Falls said:slowteg97 said:idk gig's 1in soacer really only gave him 1in of lift the rest is made up by his tires they are giving him the other 1/2 in on lift. [/QUOTE
Thats incorrect. He has a Toytec spacer which is a 1/2 inch spacer which yields 1" of lift. You are correct about the tires having an add'l 1/2 , but really has noting to do with spacer issues/lift were talking about .
BlairB said:Thats incorrect, a spacer on this type of suspension will add more lift than the actual spacer height. Argue all you want about this, but this is just how the dynamics of the suspension works, its not a 1:1 thing.
I cannot count how many guys can testify to this, including myself.
Mike and Blair are correct. Spacers yield closer to a 2:1 ratio of lift. Can I ask that you show the "proof" that you have seen twice?
Not to "jump all over your shit" of course. :bash: :lmao:
slowteg97 said:falls not to jump all over your shit...
slowteg97 said:oh and hb my proof is in the pics gig used a 1inch top spacer and got 1in of lift plus alittle extra with his tires, and i used a 2 inch spacer and got 2in of lift in the front read the entire post and look at the pics next time thanks
slowteg97 said:i guess myslef and gig just got lucky then?
BlairB said:Toytec spacers give more lift than just the height of the spacer, they name their spacers based upon the amount of lift they give, rather than the actual spacer height. Their 1 inch spacer, is not in actuality 1 inch tall, it just yields that amount of lift. I would guess that is what Gig has.
For your case, I would guess that some sort of mismeasurement would be a lot more likely than your lift somehow defying the same physics countless others suspensions
borgzman said:HB 4X4,
In you sig is Cornfed 2/1 and 3/2..you had spacer lift b4 the SAW? and is the SAW the same as the Race Runner Coilover?
and they are are avail in 2.0 and 2.5?![]()
