Lift or Leveling options
Jay Rob
Just traded my heavily modified and lifted tacoma for a 4R. Without going overboard what are the easiest ways to SLIGHTLY lift or level these things? Just to make it aggressive and not kill MPG. The 4R is a whole new territory for me over the Tacoma.
First you should do a search. With that said, you will rapidly determine that the toytec spacer lift or the Bilstein Shock adder will fit your needs.
throw on that ultimente toytec lift! go big or go home:party:
Had the Ultimate kit on my Tacoma at first and removed it after 6 months. Ride was too stiff and it kept blowing CV boots. I did have it adjusted a bit higher than the stock setting which I suppose was too much. That kit got replaced with a 4.5' RCD kit which was AWESOME in ride and functionality. This time I just want my lift to be simple. Just aggressive looking W/O killing my MPG. I'm looking into Toytec now but still considering all other options. Toytec actually features my tacoma in their catalogue for their Ultimate Lift Kit.
I did the toytec spacer lift to fit bigger, aggressive tires. My off-roading mainly consists of beach driving, so it does the job well. If you are going to do serious off-roading go with adjustable shocks, better springs, UCA's, etc.
That is the exact type of driving I'm doing most of.
I installed bilstein 5100 up front set to the 2nd to the last setting which is suppose to be 1.75, last setting is 2.5 which I used in my tacoma but it got really loose on the highway and slight wind would blow it off. I kept my rear stocks but it seems a tad bit lower than the front. I have 285/70/17s and I think the .85 setting may a be the best leveling option if you keep the rear at stock height however with the 285s at .85 setting may be just a tad to lower for the size of the tire. I am still contemplating on keeping the 1.75 or going down to .85, another option would be adding a 1.5 toytec spacer in the rear. so much to think about :cry: i've been searching the thread and haven't really found anything on bilstein leveling at 1.75 with 1.5 toytec spacers.
I don't think anyone has used the Toytec 1.5 rear spacers because they cost almost twice as much as the Daystars and do the exact same thing. There's nothing high tech about a rear coil spacer and a bunch of companys make them.You already asked before and robotkiller gave you the link to the Daystars and people on the forum have them on already.
Rear spacers-
Toytec.........Rear 1.5" lift Black Spacers Poly for FJ/4Runner - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
Daystar.........Amazon.com: Daystar KT09127BK Comfort Ride 1.5" Rear Coil Spring Spacer Kit: Automotive
Ready lift....$439 for a spacer kit=rip off - point being notice the rear spacers .....Toyota FJ Cruiser & 4Runner SST Lift Kit: 2003-2009 - 3.0"F/2.0"R
Rancho ??..............2003-2010 Toyota 4Runner Coil Spring Spacer - Suspension - Rancho, Rear 03-10 4Runner Coil Spring Spacer - 7926-03039459 - PartsGeek
Truxx...........2003-2010 Toyota 4Runner Coil Spring Spacer - Suspension - Rancho, Rear 03-10 4Runner Coil Spring Spacer - 7926-03039459 - PartsGeek
Cornfed 10-11* Toyota 4Runner Cornfed Suspension Lift kits
and the list goes on...........
thanks harper, I was unsure about the daystar one since the link says it will not fit my 2011 4runner. did a bit of search and found theyre the same with the fj :thanks:
Rear spacers-
I think this is the option I'm looking at the heaviest. Any of you guys with this setup have any pics?
I got the Toytec rear spacers since I bought the 2" front spacer from them...adding them together dropped the total price so I am happy ;) Ride is good...no noticeable change.
Easiest and cheapest lift for the 5th Gens. This is the whole 2.5/1.5 kit from Daystar(of which I'm in no way affiliated) I bought Toytec too when I first got my Limited because I didn't know then. Daystar KT09115BK at AutoAnything
Especially if you have a Limited because of the supplied bolt extensions for the top plate so you don't have to compress the front springs.
Hey Harper,
Just want to be sure you are recommending this Daystar kit for us LE owners who want a simple leveling kit, and as little hassle as possible?? Will a dealership install these? I have a new 2011 LE, and sure don't want to have/create issues..
Thanks a bunch, I've sure enjoyed reading all your posts on here.
This is my 3"/1.5" toytec spacer lift set up before the icon suspension where installed.
I am thinking of purchasing the Daystar kit. How would this look with a stock size tire? I just purchased some Yoko Geolander ATS's and do not want to replace them already.
TerryNap61
