Lift Springs and Spacers
curtperry
Lift Springs and Spacers - Everett, WA
Got the Tundra/Billies/LC lift installed, no longer need this stuff. Prefer local (Everett, WA) but will ship, can keep it cheap with USPS within continental US i think - probably $30 or less for the largest stuff.
Send me your zip code and item/items wanted and I can get you a shipping quote.
2nd Gen Items:
Rear FJ80 LandCruiser coils - $30
unknown mileage, White-White/Blue and Green-Green/Orange, they sit at about 16" uncompressed, came off a LC with 9 wraps up front so might be a bit taller than normal, unsure​
3rd Gen Items:
Stock '99 "tall" springs - $50 per pair or $80 for all 4
just removed from my rig (i had these with spacers) - My 4runner is "true mileage unknown" and reads 330k but the cluster isn't original - did not appear to be sagging, currently measuring 14.5" front and 16" rear uncompressed
Front Passenger Side Springs - Blue / Yellow (48131-35400)
Front Driver Side Springs - Blue / Pink (48131 - 35350)
Both Rear Springs - Yellow / Red (48231 - 35210)​
Revtek 2.25" lift Spacers front+rear - $50 per pair or $80 for set *pending
Front spacer is aluminum with black coating, pre-load type, measures 1.375" thick which gives same lift as rear AFAIK
Rear is black polyurethane, fits around stock "cone" bumpstop, measures 2.25"​
OME 890 Rear Springs - $80 *sold
bought em for $80 from user PNW4runner and went with 8-wraps instead, look brand new or very lightly used, still have clean stickers on em, came with the box but i threw it out​
Front FJ80 LandCruiser 9-wrap coils - $50 *sold
for ~5" lift on our rear, unknown mileage
21" Blue Pink White 9.25 wraps
21" Grey Orange White 9.25 wraps​
What will be needed to match the LC 9 WRAPS
You can use pretty much any rear shock meant for a 80 series LC. I used stock toyota (tokico made) shocks with my 8 wraps and they should work for 9 wraps as well.
If you were referring to what front setup matches 9 wraps in the back, you are probably looking at something like the toytec coilovers or 3" lift springs with spacers on top and maybe some upper control arms to correct the upper ball joint angle. Of course it all depends based on what you have in terms of current mods and what load you carry.
