Lift/Tire/Wheel central
Tundra trd bilstein 5100. 3rd notch in front. 5100 in rear with lc 8 wraps. Goodyear duratracs 285/75r16. No spacers. LR uca.
Would those rub the stock UCA?
Like your led bar inside the cab. How does that work for you.
lol sorry that's not my led bar it's my wink mirror just wrapped in camo duct tape which makes it look the a light bar, haha got a lot of people asking about that so recently I took the tape off
What I got
Alright I could use some help figuring out what exactly I have and what I should change or keep the same. I have never touched my suspension other than adding 1.5in spacers in the back to fix the rake. I've had my runner for about 5 years now, the previous owner did some suspension work to raise the ride some but I have never had the expertise or money to check it out and fix what needs fixing.
So heres what I have:
Bilstein 4600s all around (I'm pretty sure they're 4600's, the blue and yellow ones)
Stock springs all around (I'm pretty sure, could be wrong)
1.5" spacers in the back to fix the rear sag, added about a year of ownership
I have never measured how much higher than stock I ride, but I would estimate it about 2-3".
I have 223k on her. I dont know if the springs have ever been replaces, but lately I have been noticing a pretty rough ride and sag in the back with a minimal load.
My tax return is on its way so if any of this is wrong or easily upgraded I would like to fix it.
Would OME 891's work with the 4600s in the back? I carry a pretty heavy load for interstate trips most weekends so I'd like to keep the ride balanced, fairly smooth, and lifted.
Any help is appreciated, again I'm new at this. Thanks in advance.
Heres how she sits now:
Is it possible??
I am looking to run 295/55/20 with jba off-road upper control arms, I will be going with 20x10 fuel rims and probably going to do a body chop kit. I am just wondering if this will work without major cutting or modification besides the body chop. I have a toyotec boss lift which is 2" in the rear and 2.75 in the front. Just need some advice and opinions.
2002 sr5 w/ 880/906 ome and KYB gas adjust. Can I go 285/75/16 with vision 8 d windows wheel?
Here is the wheel spec:
Size : 16x8 Bolt : 6x5.5 Offset : -12 Hub Size : 108.0 Load : 2100 Backspace : 4.03
More pics please...
Not to be bossy... but there are to many will this fit my truck questions and not enough pictures! Need some more 3rd gen tire and wheel porn please!!!
4Runner Bilstein 5100s up front with stock springs, 4Runner Bilstein 5100s out back with stock springs and 1.5” spacers, 275/70 17 KO2s, MB Wheels 352
