VERY interested in your tube mount! Would this work with the CBI front hitch? Could it be easily modified to?
Hey Stellar - Welcome to Denver!Don't say that ColoRig. I just moved to Denver a couple months ago. Getting backed into regularly is not on my to-do list.
Hi Mojave,
".....Are you also looking for a tube version with tabs, or an LED bar mounted in the place of the tube in front of the bumper like that?"
I am looking for a tube version with tabs for more mounting options. Also, I have been backed into so many time here in Denver, I feel the LED between the brackets alone would be rather vulnerable.
i think that mounting tabs on a bar would be better as well. would be great to have tabs to mount a bar on top as well as the bottom of the bar
Gettin pretty psyched about this. Rough guess on shipping to Denver?
I wonder if you could ship it without the light tabs welded on? I'd like to mount them different that what's on the pic
I agree with you two. Ideally for me I'd like to have tabs off of the bottom tube for the LED bar setup so it can provide protection for the light bar.
Something somewhat similar to the positioning of the upper light bar in this picture is what I'm thinking.
I'm interested in the tube option with tabs for 7" lights like in the photo you posted of the Tacoma.
If the tabs are costly to mfg and weld on I can make my own no problem. I've been hunting for something like this recently. $150 is just cheap enough to keep me from trying to do this myself. Thanks for taking the time to make this. I'm glad there is a lot of interest.
*edit* Do you have any photos of the tube style with lights mounted on it?
Dang, 3 posts in a row.
These are the bars I am modeling off of. Standard CREE 30" bar from Amazon. 30.7" wide at the mounting points. If anyone has a preferred source please let me know, I want to make sure they are designed to fit bars that most are using. The Rigid ones are different measurements, but I don't see as many people running them as the higher cost...
http://www.amazon.com/OPT7®-Off-Roa...d=1419824895&sr=8-2&keywords=30+led+light+bar
Amazon.com: OPT7® C1 30" Off-Road LED Light Bar w/ Wire Harness and Switch - 180w Spot Flood Combo Auxiliary Lamp: Automotive
That's perfect! I have that light bar mounted to my bumper now, so moving it to the bar would work out great!
That bar looks great! Pending space there is also the 32" bar. Personally I'd be happy with either as long as it could fill up the space between the gussets. *Assuming there will be gussets on the face like in the first picture off the blue Tacoma
Amazon.com: Eyourlife 32" 180W 13500LM Off Road Led Light Bar Flood/Spot Combo Beam Waterproof: Automotive
I'm definitely interested on the smaller option if you can make some brackets that bolt in to stock locations and mount stealth behind the bumper/grille area. I would buy one for sure!
