Limited Edition Mod Thread
do the spidertrax prevent rubbing? I just got a new limited a few weeks ago and would like a similar set up if it wont lead to any headaches
It's actually the opposite. No rubbing when I had 275/55/20 KO2's installed. After installing the spacers, rubbing was noticeable only at full lock in reverse. The simple fix was to push back the liners with a heat gun where the rubbing occurred. Or you could get a lift.
gotcha thanks
Full Budbuilt skids, bumpout slliders, front and rear bumpers. Close to GVW; offroad 90% of the time now. Reliable and ~17 MPG at 5,000+ feet; but the darn thing won't float. Side2.jpg
Some sweet trucks in this thread!!
Looking to lift my wifes new 2016 Blizzard Pearl LE but she wants to keep the XREAS and factory wheels....Boo I know. I've boiled it down to either the Toytec 2.5/1.5 spacer lift or the 2/1 spacer lift from Burtman Industries. What would be the better choice or will I here a spacer is a spacer?
For tires I'm thinking 275/55/20 Toyo AT2 as she likes that tire on the factory wheels. Also, some Spidertrax 1.25 spacers. Looking forward to your comments/advise!
Check out my build thread in my sig.
I did a Toytec Boss Ultimate lift in the front, and normal Toytec ultimate lift in the back. Ended up being a 2.5" in the front and about 1-1.5" in the back. Turned out nice, and with 285/65-r18 tires.. Had to do a front liner push forward, and cut the limited front fender plastic a bit. Worth the $1800 or so for the Boss 2.5 lift though, at least in my mind...
Here's our 2014 LE
XREAS removed, replaced with Sonoran Steel 3 inch lift, 275/60/20 Yokohama Geolander A/T G015, Spidertrax 1.25 waiting to be installed
I considered a spacer lift, decided to bite the bullet and just switch it all out now.
Bunkstaff
