LLAMA Tales Thread
What!?! no pic with the lights on behind the grill...that last pic loosk like I can't aim anything, lol.
Those things are never coming off...
I couldn't connect to T4R.ORG after that post, so i couldn't finish posting. The wiring was the worse part for me, the lights just plug in.
So here's the lights on behind the grill!!
Mission accomplished!!
Put lights on behind the grill without replacing OEM grill!!! :banana:
The grill doesn't block much of the lights if anything..
Obligatory lights
Just head lights:
Head lights with 2 X 6" Rigids
With high beams and Rigids:
What i found out from this and looking at lights is the OEM fog lights turn off when I turn on the high beams.. What is the reason for that??!!
Can't say enough, a big thank you to [MENTION=50210]KVA[/MENTION] :thanks:
Were you parked at an angle? The light pattern looks like a different height on each side in that pic.
Yes I was, finding a long stretch without traffic is hard in suburbia
Though, i need to aim one of the lights up a little, they moved when i was playing around with them recently.
You need a satoshi grill. It will look better, I have one that i will most likely part with for very cheap, but i made it myself and i wouldn't say it is the best that i have seen.
[MENTION=91899]Jhalko[/MENTION] tell me about it... One day :)
[MENTION=1598]Alex[/MENTION]T4R I dont "need one" :) I'm happy with the results and they lights are plenty bright.. You dont see any of the grill in the shadow of the light, so it's not blocking much, maybe a little..
Out with the white plastid dip .... It just wasn't doing it for me, reminded me of rice rockets when i was 17..
Before
After
Birthday present to me for me:
Now just to figure out what battery configuration to go with ...
1.
Main battery - stock battery
Second battery - deep cycle.
2.
Main battery - deep cycle
second battery - Stock.
3. ?
1.
2.
3. ?
Diehard D35 deep cycle for aux, Diehard Group 31M for primary when your current stock battery goes bad. Or you can simply fit Diehard 35D's in both locations.
If you get a Group 31M, you get 1150CCA instead of the 740CCA of the 35D.
JMTC :nerd:
Okki
AndiGarage
