Location of moon roof drain outlets
harojs
2006 4runner Sport
Location of moon roof drain outlets - I can't find them.
[W]here exactly do the two drain outlets exit the body? Pics?
I need to clean the drains from the outlet up to the moon roof because my moon roof cable is stuck shut and I can't clean from the top drains down as you would normally.
Found where the drain tube exits
Found where the drain tube exits into the lower area inside the drivers side quarter panel behind the mud flap.
That area behind the mudflap was packed full of little seeds and the drain tube got plugged.
I had to remove the mudflap screws and clips and was sort of able to vacuum out that area using a stick.
Still not happy clearing that area out - now way to open it.
How would you get in there? - remove the quarter panel?
John
MikeV5280
