Losing 10lbs of air in 3 weeks
JP4RNR
06 4Runner 2WD with stock Bridgestones
The right rear tire keeps losing air about 10lbs in 3 weeks but I cannot find a nail in it. Valve stem maybe? I have 37000 miles on the tires
You've either got a bad/loose valve stem or a hole somewhere in the tire. If it were me, I'd inflate it to about 35 lbs and dunk it in a tub of water. Wherever there are leaks you'll see bubbles.
I had the same issue with my work truck 2 weeks ago(both rears). I took it to the service station to get looked at. Both rear tires had nails in them. $40 later they were patched and ready to go.
You definitely have a nail in your tire. Hopefully it can be patched and you will be good to go.
You have a leak! Take it to a tire shop and let them dunk the tire in the tub of water, to find the leak.
Koz
I had a tire with a leak like that and I took it back to the tire place. He insisted that the tire was fine. After awhile of constantly checking the tie, I bought a can of tire stop leak, it is a can of air with something that stops a small leak.
DO NOT use this stuff on any vehicle equipped with tire sensors, unless you want to buy new ones.
I had this problem happen to me 2 times in the past,same tire.
Shop couldnt find leaks due to punctures or valve stem problems.
He said it was probably grit/dirt somehow got in the bead between rim and tire.
Both times it happened after using the car wash with tracks.
I normally dont use it but in the winter time I dont like leaving road salt on the paint.
Bones
goddesszilla
