Loud Idle/Acceleration + Tire Cupping Questions
sxhaller
I recently purchased a '00 T4R SR5 with 205k miles on it (one owner, most service records, clean condition). Except for a minor cupping on the tires and a small oil leak, the truck is good condition. I was previously told by American Tire Co that the cupping on the tires was minor and would fix itself with on time rotations. Other than a rough ride (have Goodyear Wrangler Authority), I haven't had any issues with loss of grip or bad handling... until yesterday when we had rain.
I was fine driving on the freeway around 70mph but once I got off and made a small turn (not speeding), I loss control and drove left into the plants in the middle divider and swerved right across two lanes before obtaining control. My only guess is i had some water and with the cupping, lost control. The truck was driving fine except I noticed that when I accelerated, I started getting a whinny, almost chainsaw type of sound. I am now noticing it every time I hit the gas and the more I push it, the louder it gets. I also noticed that during idle, the RPH fluctuates from 600-1100. The higher the RPH, the better "grr" I hear, but when it goes around 900, it sounds like a chainsaw idling.
Any suggestions on what this may be?
Also, is the minor cupping (per the tire guy) an issue enough where I should replace them? Before this, I have never heard of tire cupping.
Thanks in advance.
On a rear wheel drive vehicle the front will cup out like that and the rear will wear flat. You can either replace them or just deal with the 2 cupping out some. With rotating them it will eventually fix itself but could become noisy slight roar. But the tires cupping should have not made you slide or lose control.
So the noise started after you hit the plants? I'd check everything out under the hood and under the truck.
