Cygan1008
That sounds more like a CV joint being worn out. When you lifted it you may have unseated the boot and over time leaked the grease out.
The boots did leak a little but were re sealed with new clamps with in 30 miles of installing the lift. There are only about 700 miles on the lift now. The popping didn't start until after the new lca bushings and alignment were done with in 100 miles from installing the lift. I highly doubt the cvs wore out with in 30 miles after loosing a tiny bit of grease. I'm wondering if it's just the change in suspension angles on parts that have been seated in place for 166k miles either way I am going to start whittling away at components. I plan on upgrading the xreas ASAP and will probably change most other the other components at that time if not all of them. I want everything to have grease fittings anyway.
OP, I will let you know what I come up with but mine will take some time. Please let me know if you come up with anything as well.
