LR Uca seized bolt??
ofcbarbrady
I'm soooooooooo pissed right now.....hopefully someone has an answered. Installed my Toytec Ultimate yesterday and LR Uca's....the shop that did it still has my truck. They said there is a seized bolt on one of the control arms that is causing trouble in fixing the alignment. But here is what I don't understand.......they said they may have to switch back to the factory control arms to fix it. If there is a seized bolt, how are they able to switch back and forth with control arms but not get the alignment right????
Problem solved.........the guy doing the alignment found the problem. He said the guy who installed the Uca's had them backwards??? Is that possible??
Here's everything finally on!!!!!!!!!!!!!!!!!
What are your initial thoughts of the Toytec kit? I am deciding between these and the 2.0" Radflo kit. Also is it just the driveway or is the back sitting a little low?
It's in the driveway.......have a pretty good incline going there. The last time I had a lifted truck was my Jeep in the early '90s. But as far as I can tell --- I absolutely love it. It rides great. Don't reall see a difference between this and the XREAS as of now (although I have only driven it 15 miles so far) except the noise due to the Trail Grapplers -which is fine by me -
Some crappy pics I took are in teh Lift&Tire section and Picture thread.......I'll get more this weekend.
Ya I saw the other pics, looks great man. Looking forward to what you think of the Toytecs after some miles on them.
Agreed, something sounds fishy..
Ok....i checked it out and you were right. The front is a little less than 1/4" higher than the rear. Now my question for everyone (including the guys from Toytec) is -- do I leave it and wait till everything settles (I am also going to be dropping my spare) or do I make the adjustment now?? I read all I need to do is lift it up, turn the wheel and I can use the spanner wrench to make a correction. I don't want to take it back to the ****s that installed. Here's another pic of it.
TerryNap61
