I have no idea why this happened, but the first 3 or so threads on my passenger side rear lower shock mount are absolutely buggered. The bolt will thread in a bit, then stops dead in its tracks. The rest of the threads look just fine, and the bolt looks fine, except for the very end of the bolt. The bolt came out fine, but will not go back in. Very odd.
I'm thinking that running an M12x1.25 tap through the hole should clean things up enough. What should I do if that doesn't work? I would rather not drill it out for a larger bolt since only the first 3-4 threads are buggered.
Suggestions? I do have a torque wrench and the bolt was previously torqued to spec at 75 ft/lbs.
