Manual shift into 2wd
01_4_runner
What pins are required to shift my t case into 2wd? Just need to shift it for now so I can drive it around. What pins on the actuator do I need to send 12v to so it will move into 2wd?
Sent from my SM-G950W using Tapatalk
What year? Auto or manual?
Is your t-case shifter not working?
2001 automatic the actuator is not working right now and I currently cant drive it unless it goes into 2wd.
Found what I was looking for guys. I'll leave this here in case anyone wants to do the same thing
Goes into 2WD? It should be in 2WD by default.
Why can't you drive it?
It sounds like when I put mine in AWD with the front hubs not locked- I can't move until I lock the center diff.
In order for your picture to be of any help to anyone in the future, you really need to provide more info on what's going on.
What does "I can't move" mean? Engine free revs like it's in neutral? Engine under load, but won't move- like your standing on the brake?
The front diff is stuck in neutral and the transfer case is stuck in awd. So when i try to move it the case trys to send power to the front wheels doing nothing. If I get it to shift into 2wd the car will be driveable.
Okay, so exactly the situation I gave the example of.
You said "if I get...", does that mean you have yet to be successful in getting your rig drivable?
I tried but it seems like the transfer case actuator is shot so I'll probably lock the add in place with a hose clamp and keep it in awd all the time.
I'm betting it's a switch that's stuck, and much more simple of a fix than it's seeming like to you.
I have a wiring diagram for an '01- would you like me to help send power to the actuator to test it? You can use a 9v battery and a couple pieces of wire.
erinobr2000
