!!MASTER CONTROL SWITCH ISSUES!! '95 Runner
JediRunner
Recently picked up a 95 4runner with only 110,000 miles on it, seemed too good to be true... and it might be! sort of... my power windows crapped out with the 2 front windows down.
The lock switch on the passenger front door works, none of the window switches including sun roof, backseat windows and tail gate switch will work. and the tail gate window will work with the key. The mirror adjuster still works right above the master control switch.
looked like a switch issue so i replaced the master control switch because after cracking open the old one i saw the copper pieces looked charred. however this DID NOT resolve the issue.
does no seem like a fuse issue, i hope it's not wiring. Any input would be appreciated
Sounds like fuses to me. Check under the drivers kick panel as well as under the hood.
If that dosent work, attack the truck with a volt meter.
Im with hyde, maybe if one window went out but your saying none of your windows work with the switch. Telling me the switch it's self is not getting power. check all your fuses for continuity including under hood fuses. Since everything went out, to include the sunroof. Id put my money on one of the bigger ones under the hood.
Clocktower07
