Maximum safe caster angle.
ZXROM
I'm curios as to how much positive caster everyone is running with their SPC adjustable control arms. I do my own alignments, I work at a shop, and right now I'm pretty close to 5 degrees with SPC uppers set at default and cams maxed out, I'm happy with how the truck handles, but I want to try and get 5+ degrees out of it. Mainly to get away from the cab mounts (I run 34s). I'm considering a "bmc", but first I wanted to find out how much positive caster is too much. If anyone has any experience with this chime in!
Mine's at +4 deg. I wanted enough to feel stable and prevent bump steer over the friggin pot-holed mess we call roads.
Just my 2 pennies
I don't think there is such a thing as safe caster angle it really depends on the suspension geometry and manufacturers design, that being said I'm sure you know this Caster is a non wearing angle you can max out your caster and will not eat up your tires but it can affect the way it handles and steer or even cause a drift or pull if not properly adjusted. Having 4-5* of caster is a lot for these vehicles unlike European cars which can go as high as 11* but that is just the way they are designed. I would play with it if I were you since you have access to an alignment machine and see what happens, I use to dial in my own alignments too when I had an alignment machine to play with.
I can't weigh in on what's safe or unsafe as I'm no expert.
That being said I have run between 4-5* of caster for about 6 years without any problems. I am at 4.9* now which seems to be the max on my setup to get everything to align correctly.
A couple years ago I did have a tech at a reputable 4x4 shop tell me he wouldn't push the caster above 3* because it would cause wheel "flop". I immediately went to another shop who set it to 4.5*
I have total chaos UCA's. They aren't adjustable like the SPCs, but they have a +4 caster built in. So when I get my alignment my caster is usually 4.75-4.95 depending on the tech. Running 285/70's and no rubbing whatsoever. If I had 285/75 then some kind of body mod would be necessary. But to answer your question, a caster at 5 isn't too uncommon as long as the geometry allows it like one of the replies was stating.
I run right at 6 if not a little over. Might not be applicable, but I figured the 4th and 5th gen geometry is probably very close. Truck drives great though
Wheel flop?
Did he explain what he meant by wheel flop? Never heard of the term and I've been turning wrench for almost 30 years.
Jaming in more caster with the SPC UCAs will move your tire into the body mount more.
The 3rd gen guys figured it out.
Orange is caster# the SPC arms do.
I didn't get into it too much with him as he couldn't answer my primary question which was why didn't you leave it with the 4* it had when I brought it in.
Basically he said the steering wheel would feel heavy and smooth movement of the wheel would be inhibited due to "wheel flop"
Most likely a lazy tech who didn't want to align it again
