Member Skills Wanted....
AustinClash
in Orange County, CA who would be able and willing to help me (or keep me out of the way) install suspension/steering components on my 2002 T4R as an alternative to a repair shop.
Coil springs, shocks, BJs, etc, maybe even Tundra brakes down the line.
I will buy the parts from the varous sources linked/recommended from other members here.
Compensation with U.S. Currency or food and beer, which ever preferred!
PM me.
AC.
If you were about a month earlier, I would be able to help. If you dont have any luck finding someone pm me and I will give you a couple numbers to buddies that do side work for a reasonable price.
I also like beer, but I'm a bit of a commute from you.
I used the Toytec install instructions, and took the spring/strut assemblies to a shop and had the springs swapped over for me, then reinstalled. Everything else is easily DIY if you follow the instructions. If you are replacing the struts, cut the rears off with a sawzall, saves lots of frustration.
The LBJ install went alright as well, get a 2-jaw puller to pop the balljoint out of the LCA ($10 tool), and use locktight on the bolts.
Each of these jobs requires an alignment afterwards, so plan your work wisely and only get the alignment once. Or, get a lifetime alignment package if you can find one.
lilianmarais
