mikey's2010SR5
So I believe I have tracked down my pop sound. Looks like at my last alignment the tech either left the front driver side can loose or tightened it so it was "upside down". Looking at the cam it appears to not even contact the side gusset wall, there is about a 2 mm gap on one side. It also now appears the other side is slightly bent and I mean slight. Going to get an alignment soon and have the cam flipped up and see if that helps. If there is still a gap due to the bend then a set of gussets from TC will be on order.
