Misfiring codes 2, 4 and 6
banetranch
After replacing both head gaskets, belts ect.. check engine light came on with the codes 2,4 and 6 cylinder misfiring. Checked the wires three times to make sure they were connect to the right cylinders.
Fuel injectors are 2 an 4 firing with a sethscope a new injector on number 6.
I am out of ideas and I need to get on the road. Any help I would appreciate it. Thanks
First thoughts are that the wiring to the injectors is not correct. I would double check that first.
Why were the headgaskets replaced to begin with? Was there any issue with the head that required it to be removed?
I'm almost positive the wires are correctly installed bc the harness is so tight they would not reach to any other ones
Please check again anyway. Just for me. 1-4, 3-6, 5-2.
patnewton
