Mod broghts gen 5 fog lights
Doc_Fry
Can someone point me to the 5 gen fog light mod. I saw one for the 4 gen. But it does not translate. I have a 2015 and do want fogs to sty on with brights as I am changing them out to Rigids d2s. Thanks.
Ant-Man has an awesome write here
Thanks I did see that one. But I have a few issues with it. One is I am going to retain the facotry switch. Second is his mod requires a seperate relay installed into the system. I would rather not cut the factory wiring if possible and was hoping someone did the mod at the factory relay such as the gen 4 mods. I dont see it being too difficult to do. I was again hoping someone already went through the trouble doing this and locating this relay, unless it is only controlled by the canbus, yuck. If there is a facotry relay someone in the vehicle it would also solve the issues with the light on the dash illuminating when the fog light is on. Fingers crossed!
As well as having horn issues at this time. I cannot do any modifications to the factory wiring. They refused to look troubleshoot the horn before because of an aftermarket alarm/remote start that integrated with the canbus system. I had to remove it. I have no had time nor a second vehicle to go over an hour to a dealer to be able to get it troubleshooted. So since new I still have no horn. Maybe ai should give toyota corp a call as this is a safety issue and make sure I can get a loaner vehicle. Anyways a different subject for another time.
My mod does use the factory switch. It's a work-around because the relays are sealed in a box under the dash soldered to a circuit board.
It's pretty much the only way to do it with the factory switch.
Yuck I was hoping to not to have to cut any underdash wires. I guess this is on hold until I can get the horn trouble shot to see what is causing the issue.
goddesszilla
