Model difference question for wheel swap...
NEdude
Hello -
Probably a really stupid question... Are there any reasons wheel fitment with regard to width of wheel (9") would be different on a 2018 SR5 vs. a 2018 TRD Off Road? I like the wheel on a forum members truck and just want to be sure it would 'look the same' on mine with regard to sticking out past the fender...
I have tried to find all of the spec differences but can't seem to find if this matters at all...
Thank you!
Even stock same model 4runners can have a variance in height and alignment that may require some modification. There shouldn’t be a “poke” difference between an sr5 and TRD OR with same width and offset wheels.
With that said, you should message the other user to see what mods or alignment adjustments they made in addition to the wheels. You may not need the same modifications but you can be prepared for it.
Thank you for the info, definitely good to know...
And, I did as you suggested, the other user had all of the info I could possibly need/want. I think I should be good to go.
Thanks again.
Laredotx
